Tail Lights Headache !!
1. Do I need to reset the fuse if I accidentally did something wrong ? I know the fuse is to the left of the steering wheel, but need some instructions on how to reset it.
2. If this is not the fuse what else could be causing this issue. Do I simply need to get a new housing to make this problem go away ?
3. Last night the ABS and ESP light came on, we turned the car off and it did not return this morning. I am not sure if the worn out taillight is causing this or the brake light switch needs to be replaced and will also fix the taillight. I did change the brake light switch about 8 months back on my W210 and am not sure how soon these go out.
Kindly share you tips, as I am plan on working on this item after work tonight and can pick up the parts from the MB dealer.
Cheers
Do I need a new tail light assembly ? or is this related to any fuse. I tried the indicator bulb it works just fine. Any help or pointers would be much appreciated. Also, please along links for vendors if I do indeed need a new tail light housing/ assembly to address this problem.
the loss of voltage begins. so, with lights on (and/or brake pedal depressed)
take a voltage reading off the bulb holder wings.
then, try bulb holder out and meter off the metal backing plate which serves
as a circuit board.
then, meter off the plug/connector into the tail light assembly....
i dont read much on the 210 forums where the cause is further upstream from
here, ie, into the wiring harness.
