Blinking recirc light - frustrated - would dealership even know?
Old Oct 19, 2010 | 11:25 PM
apb's Avatar
apb
08 S550, 10 GLK350, 05 Clk500
when hot outside, and especially if car was in the sun for a while, the ac unit will reset itself. What most often happens, is that when I hit the brakes fairly hard, the recirc light will blink on the display and temperature settings and fan speed will return to the setting when I first started the car. The blower shuts off and then turns back on. I do not have error codes in the ac unit. Only thing that helps is to disconnet instrument cluster, and reconnect, I am then good to go for a while. I NEVER have the problem when cluster is disconnected. And, before you ask, I one changed instrument cluster and the problem still occured. Any clues? Is this the type of stuff a tech can figure out, or am I in for a run around?
Thanks!
Old Oct 23, 2010 | 12:22 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If the tech has the MB Star diagnostic system he can probably figure it out.
Old Oct 23, 2010 | 01:34 PM
ohlord's Avatar
Appears to be a
loose harness or fault wire something is shifting with the brake force G's and losing power for a short period.
You changed the cc unit,have you inspected the plug harness and wires?
Old Oct 23, 2010 | 03:08 PM
apb's Avatar
apb
I have not changed the climate control unit. I did change the instrument cluster but all the connections appear just fine... And I do not get fault codes from my cc unit when retrieving then on the display...
