Speakers inside the dashboard in 1997 E420 W/Bose
Old Apr 23, 2003 | 06:28 PM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
Thumbs up Speakers inside the dashboard in 1997 E420 W/Bose
Hi All,
I know this question should belong to another thread, but I should get more response from here !!
I try to upgrade my speakers and I found out there are 2 speaker inside the front dashboard that close to windows. I have Bose system and what is that speaker for ? mid range ? thanks in advance !!
trustz
Old Apr 23, 2003 | 07:00 PM
Turbo]['s Avatar
98 E430
on my 1998 E430, the two speakers on near each a/c vents are actually for the hands free kit. however you can take them out and use them for your stereo.
Old Apr 23, 2003 | 08:51 PM
Das E320's Avatar
1998 E320
Are you serious???
I thouhgt those were tweeters. IF I wanted to hook up an aftermarket phone in the car can I access them instead of the generic box speaker that the kit comes with?
Old Apr 23, 2003 | 10:14 PM
Turbo]['s Avatar
98 E430
Yes, they are on the driver side trunk area, behind all the carpettings...at least that's where the module for the cellular phone connector is.
The door speakers are 6.5" with a tweeter built in front of the 6.5" driver
Old Apr 24, 2003 | 01:59 PM
trustz's Avatar
Thumbs up
Turbo][:
Thanks a lot !! one more question: where is the Bose amp locate ? I got a idea to upgrade the system. If I install a new Sony head unit and by pass the Bose amp ( conect Bose amp "in" wires with "out" wires directly-- without conect to the amp). also install new speakers at the same time, will this work ? everyone try this before ? thanks
look like this:
BEFORE:
[head unit]---in wires-------[Bose AMP]-------out wires---[speakers]
AFTER:
[Sony unit]----in wires--------------------------out wires-----[speakers]
.........................................[Bose AMP].......................................
Trustz
Old Apr 24, 2003 | 02:02 PM
Turbo]['s Avatar
98 E430
The Bose amp is exactly the same place as the hardness for the HFS. You'll see the rectangular box.
Old Apr 24, 2003 | 05:40 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
You should be able to bypass the Bose amp and connect directly to the speakers off of the head unit as long as the speakers have a negative lead and a postive lead. But why would you want to do that? I would change the head unit and connect it to a new small amp in the trunk and then run the speakers from there. Just the head unit alone will not have the power that the bose amp has to get good sound out of the stock speakers. Just my suggestion as I used to be an audio installer back in the day. Still play around a little but a bit rusty but it's like riding a bike, you never forget the basics and then some...
Old Apr 24, 2003 | 06:31 PM
trustz's Avatar
Thumbs up
Jimmy:
Thanks for the info, I did think about to put a amp, what is a good 4 ch amp to run my door speakers ? I am not too crazy about the sound system, just something a little batter than Bose system, compare the E420 Bose system to my Q45 system. I feel fine with the Q45 Bose sound system ! Whats the good amp I can put in my E420 ? I am thinking about 50W per ch. Kenwood ? a/d/s ? any suggestion ? Thanks
Trustz
Old Apr 24, 2003 | 06:45 PM
There are too many to chose from and the ones you mentioned will probably do. But, it depends on the quality of sound you want and the what options you like. Check this link out to compare a variety of different amps: http://www.sounddomain.com/shop/amps If you were asking me my opinion, here is one of my favorite amps as it is low cost, 5 chanels to run an entire mid-level system and just a kick a** amp all around. I just installed one of these in my friend's BMW and wow! Check it out and let me know what you think: http://www.nowonsale.com/ppf/itemnam...0/itempage.asp
Old Apr 24, 2003 | 07:05 PM
Turbo]['s Avatar
98 E430
Or Get this set up!!
