Break Pads
Old Dec 1, 2010 | 10:44 PM
zheka's Avatar
2001 E320
Question Break Pads
So I got this msg on dashboard few days a go, "BRAKE LINING WEAR visit workshop". From searching this site, and google, its most likely my pads are going out.
Should take it to the indy shop to get them replace?
Should I replace all 4 pads?
Any specific pads I should STAY AWAY from? (I want the least dust pads possible)
Any best pads I should get?
Easy enough to get the pads replaced on W210?
Old Dec 1, 2010 | 11:12 PM
zheka's Avatar
2001 E320
and if somebody finds a really good DIY changing break pads, before I do, I'd really appreciate.
Old Dec 1, 2010 | 11:24 PM
ohlord's Avatar
top of the forum
gregs210 diy for brakes
or the diy section on www.benzworld.org w210 forum diy
Easy job
order akebono pads if you want little dust.
tirerack carries them.
Be sure to use pad paste
you can do it
only replace the end of the car with the worn pads
to tell that you need to look.
Autohausaz.com has the sensors 2 for the front 1 for the pass rear
Old Dec 1, 2010 | 11:28 PM
zheka's Avatar
2001 E320
Thank you!!
One more quick question. What price range am I looking to spend on the pads replacement?
Old Dec 1, 2010 | 11:37 PM
ohlord's Avatar
Doing it yourself?
About 50 bucks or less.
or more if your rotors are not smooth.
having a shop do it
depends
having the dealer do it several hundred bucks at minimum
really easy to do yourself though
pm me for tips if you want to learn
Old Dec 1, 2010 | 11:44 PM
zheka's Avatar
2001 E320
I am pretty confident on replacing them, its just I work in a computer field, so I dont like to get dirty LOL!!! I did changed the water pump on my own, so I can follow directions, to save money having somebody else do it...
Do I need to buy sensors as well? I am kinda confused on what parts I have to buy... The DIY pdf, said I'll need to buy the clips as well? What parts will I have to buy. And are all the parts available locally? Or I have to order parts online?
Old Dec 2, 2010 | 07:33 AM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
You do need to replace sensors
Once you've got the message on the display it means the sensors are rubbing. They are very inexpensive.
Have fun.
Old Dec 2, 2010 | 05:02 PM
zheka's Avatar
2001 E320
Ok, so this is what I got at Advanced Auto Parts
$50 for the front pads
$50 for the back
$25 for 4 sensors
$4 for the brake lube
Thats all what I need?
