E300D vs. E300TD - your input
In my lurking I have learned the earlier W210 '96/'97 cars were non-turbo motors. I am looking for a strictly highway commuter (I do ~35K annually). I am capable of doing all my own service/mechanical work. High horsepower is really irrelevant to me as I just want a comfortable car to bomb down the highway in with the cruise set, as I have a seperate weekend toy to play with. My budget is ~$10K, and I have been able to find some very nice one owner, documented maintenance, non turbo's for less than that amount, and a few TD's for a bit more.
Bottom line: if one does not care about speed, should I save a few bucks and go with a well maintained non-turbo, or is there a compelling reason to go to the later '98+ turbo diesel? Is highway mpg's comparable? are the drivetrains as stout as the later TD? etc.
Thanks!!!!
I would go to the www.peachparts.com forum. There are a ton of members there that drive turbo and non-turbo W210s. In my experience, I don't achieve anything higher than 29mpg with my turbo. It's a fun, quick and mostly reliable vehicle. I believe the E300D has a different transmission than the 98-99 E300DT's
The power of the turbo motor is nice to have, but not necessary. It is slow, but driving it often, you get used to it quick.
I currently work ~75 miles from my home, so my commute is 150 miles/day, 5days/week. My commute is flat, and about 73 miles of interstate. I really am not looking for sport, just a car of substance with a comfortable ride/interior, that can pull down respectable highway mpg's. I like the diesels for their longevity.
I have a sportbike to get my speed thrills, and the makings of a high compression VW track car to get the loud, rattle, stiff ride sports car vibe if I ever put all the pieces together.
That said I may do a few cosmetic upgrades to bring a bit more sporting look to it. I think a lower stance and wheel/tire upgrade sets these cars off while maintaining a classy look, though with as many miles as I do I don't want to end up with crap ride quality.
I'm leaning towards the non-turbo simply for the fact that I am finding them at better prices with excellent maintenance history, owner history, etc.
It's good to hear a few votes of confidence for the non-turbo model.
The non-turbo has no MAF (only an inlet-air-temperature sensor) and the EGR can be closed without triggering a CEL, giving you a smooth running engine with clean intake.
Glowplugs are also easier to replace on the non-turbo.
If only for commuting on cruise-control I would get the non-turbo. Change the tranny oil and filter and you'd be good to go for a long time...
Get the Turbodiesel.
Regarding the MAF, if it ever goes bad, it'll throw an OBD 2 code idicating it and is a 10 min job to fix. Doesn't happen too often. Haven't heard of too many folks having unreasnable soot accumulation on the intake manifold. I believe someone has developed an EGR bypass that won't throw a code should you want to go that route.
WHEN, not if, you do glowplugs, you'll be removing the intake manifold to make life easy for yourself. Do some searching on the 'net and you'll ream the threads, reinstall new plugs with antiseize, and then run Powerservice DieselKleen in EVERY tankfull. I replaced all of mine because one went bad at @60000 with Bosch ones and now have @150000 with NO issues.
Get the Turbodieeel.
Highway commute? Nice to have 174hp/243 ft/lb versus 134hp/155 ft/lb when passing. I believe the Turbo was actually rated higher EPA mileage-wise or at least the same versus the non-turbo.
The E300 Turbodiesel was the fastest production diesel in the world when it was introduced. With the non-Turbo you'll be at the mercy of every VW TDI that crosses your path. Could you sleep at night knowing that?
Get the Turbodiesel!!!
But either way, you can't go wrong. If you are mechanically inclined, much can be repaired on your own.
I'm not opposed to a turbo if I find one in range with the correct records/condition. I think i'd be happy with an NA diesel though too.
As to passing on the highway, the NA version will zoom between 3000 and 6000 rpms in a rush. The highway is where these things shine.
my turbo engine output 174 hp the regular diesel 134 you do the math , when it comes to the highway use they are the same except for the exeleration you need to get up to speed it will take 8 seconds with the TD from 0-60 and i think about 12 or 13 with the regular engine but they both ride like a plane on the highway .
