Intrument Cluster bulb
99 Mercedes E320 Sedan
Ive recently found out i have multiple bulbs in my cluster that have been burned out and was wondering if anyone had any idea as to where i could get them for cheaper. i need the white and red ones, my local stealership wants 16 bucks a bulb.....
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
i think if you search this forum, as well as the 210 forum on Benzworld,
you'll find part numbers, as well as bulb base designs, etc. others have
already scoped out these specs and have posted
'01 W210 E320 CDI
You'll need the original bulbs to get an even lighting pattern across the cluster. They all are a specific Wattage...
98 Brilliant Silver E320 Wagon
Here is a link to a site for identifying miniature which you might find useful.
http://www.miniaturebulb.com/id.html
WWW
autohausaz.com
A few bucks each.
you need the hooks also to pull the cluster.
A few bucks each.
Thanks you guys for the help really appreciate it. Ended up buying bulbs for sooooo much cheaper than the dealer from autohausaz.com. I will definatly try to remember to look through post >< Thanks Again
hi ohlord : i don't have my woners guide and i'm confused on the S/W switch , do you know what it does and when i should use it , it snows alot here in new england specialy this winter ,any responce it appriciated , thanks
Starts the
car off in second gear when in W mode allows less wheel spin in snow Ice and muddy slippery conditions.
Instrument CLuster Bulb: hooks?
where does the "hook" go and what does it look like so that i can make one out of a metal clothes hanger or like?
Thank you,
Steve
Campbell CA
Thank you,
Steve
Campbell CA
00 S430 & 02 Suzuki 750 Katana
Has anyone ever changed the buld in the the instrment cluster and dash board to a different color like "blue"? I would like to change All my interior lights to blue but I am not sure if it will all be possible please advice.
1998 E320 Sedan
On a side note, if you're going to pull the instrument cluster just replace all of the bulbs at once. I bought 2 bulbs from the dealership, for $7 each, and replaced the couple that were burnt out. Few days later two more go out so I just bought enough to replace them all from autohausaz. Like 95 cents each.
