How do I get into the instrument cluster of my '99 E300 TD?
'99 W210 E300 TD
A few months ago the left side cover for the warning lights in my instrument panel came loose and I need to move it back into position. Whenever the brights are switched on there is an unbearable light omitted. How exactly can I get in there and move it back? Any help is much appreciated.
back up one level to the 210 index. see SEARCH on right? search this forum
using keywords "instrument cluster remove" or some such
also, can go to Benzworld dot org and search the 210 forum at top (Stickies)
98 Brilliant Silver E320 Wagon
If I understand you correctly, you may not need to remove the cluster. Instead remove the plastic cover under the steering wheel. Two or three phillips screws and the air louver on the side of the transmission tunnel (rotate black plastic fastener). Reach up and adjust that piece.
I have the same problem with my instrumental panel like "djlien16" but I not quite understand how to remove this plastic in front of the instrumental panel, so please can you be more specific, thanks in advance!
Hope that helps some.
You can remove the whole instrument console by pulling it with like a coat hanger you have to use some strenght, I just have taken mine out and have send it to the United Kingdom to have it repaired as the Clock,mileage and the temperature lights went out.
