Oil Leak on 1997 E320
Old Feb 17, 2011 | 05:41 PM
phixsonw@hotmai's Avatar
1997 E320 MBZ
I have had estimates to fix what they call a head gasket causing my oil leak. One quote is $1,700. Is this a common price to repair a leaking head gasket?
Old Feb 17, 2011 | 06:44 PM
ohlord's Avatar
Where are you located?
The other question is the 1997 M104 have little issue with headgasket leaks.
The 95-96 were plagued with them.
And yes that is a bunch of money for Gasket. Almost half the value of the car.
Clean and examine the area might be just a valve cover or timing cover leak.
if it is not a compression leak of the hg monitor the oil and add as needed and drive her into the ground. Sinking 17bills into a 97 is not prudent.
Or shop around a grand or so seems to be the going rate at a good indie shop.
Old Feb 17, 2011 | 09:53 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
If your only symptom is an oil leak, I doubt that is a head gasket. As mentioned, a valve cover gasket is a more likely culprit.
In any event get a second opinion.
Old Feb 18, 2011 | 01:34 AM
stickygreen's Avatar
'97 E320
Head gasket seep at back of the motor is common on these...they don't usually burn oil, just leak externally.
$1000 is a reasonable rate for the repair...$1700 a bit high
Ours has been seeping ever-so-slightly for the last 100k+ miles, but never need to add any oil between 7.5k changes so I just deal with the occasional drop in the driveway.
Old Feb 18, 2011 | 11:31 AM
1997 E320 MBZ
I just got a 2nd opinion and his quote is $1200--much better. He actually ran dye through my car and then looked at it with an infrared light and pinpointed the lead.
Thanks to everyone for your thoughts on this.
Old Feb 18, 2011 | 11:34 AM
1997 E320 MBZ
I'm in Little Rock, AR. Do you know any good, reasonable MBZ mechanics in this area?
