LAMP WARNING LIGHT, After Tailight LED Install
Old Feb 21, 2011 | 01:21 AM
The Archman's Avatar
2011 C 300 2001 E 430
Just finished putting in rear LED tailights on my 2011 C-300. Checked all the wiring and made sure that the harness was tight. Checked all the lights, running, stop, back-up and signal lights and all work great. However I am getting a "Check Lamp" warning on my display. Anybody, had this problem with their LED tailights and this warning, and could you please help me on you fixed it?
Old Feb 21, 2011 | 02:53 AM
ohlord's Avatar
Lower
voltage has triggered an imbalance in the system. You will need to solder in the correct weighted resistor.
And then watch out since most led retro fits are barely visible from the most important angles
Old Feb 21, 2011 | 08:50 AM
juve010's Avatar
e320 4matic wagon
not to mention watch out for the heat dissipated from the resistors!!!
