Noise from catalytic converter
Old Feb 22, 2011 | 05:19 PM
dwongsam's Avatar
e320
2002 E320 89,000 miles rattling noise coming from the driver side catalytic converter when car is idling...It is intermittent...
Does anyone know what is causing the noise???
Is the cat bad or what??? Thanks for your input to this ???
D.Wongsam
Old Feb 22, 2011 | 05:44 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
D.Wongsam
Cat is going bad. Need to replace with new. Through dealer is very pricy at more than 900 per side. best to go aftermarket for considerably less. Cats in North America are under a eight year/ 80000 mile warranty from MB for free replacement if bad.
Old Feb 22, 2011 | 07:09 PM
The Archman's Avatar
2011 C 300 2001 E 430
California is the only state with catalytic converter requirements. You must buy a california approved CC. Somehow, they will know when you go to smog it. There a few CA approved aftermarket CCs on the internet.
Old Feb 23, 2011 | 07:19 AM
saintz's Avatar
GL450
A muffler shop can remove it and weld one back in.
Old Feb 23, 2011 | 04:41 PM
fosmith's Avatar
2001 E430, Obsidian Black w. Ash/Orion Grey, 195,000 mi.
If it's the rear cat that's rattling, the Magnaflow 53005 can be welded in to replace the oe unit. They are only about $65 including shipping on ebay. A competent muffler shop can weld it in for $70 or less. That won't meet California CARB rules but the only way the aftermarket cat can be detected during a smog inspection is visually and they usually never look under the car.
Fred
Old Feb 24, 2011 | 11:28 AM
ejsheltra's Avatar
Fred
Fred; That's good to know. Do you know if the pipe inlet and outlet IDs are the same as OEM? Would you happen to know if the flow rate is equal to OEM as well?
Eric
Old Feb 24, 2011 | 01:17 PM
fosmith's Avatar
Eric
The ID's are, if not exactly the same, close enough so that it welds in with no problem. I don't know the flow rate but it has been fine on my E430 so I'm sure you'll have no problems with the V6. Search this and Benzworld forums for Magnaflow 53005 and you'll find that many others have gone this route.
Fred
Old Feb 25, 2011 | 12:03 AM
blacked210's Avatar
99 Mercedes E320 Sedan
i replaced mine not too long ago the dealer in SF said most of the ones they sell are re-manufactured ones i just looked at the reicipts and they charged me 275 and a 150 core charge. idk do others dealers have the same? and gave me a 1 year warranty.
Forgot to mention this was for the one passenger side and included both Catalytic converters
Old Feb 25, 2011 | 12:16 AM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
What about a salvage yard?
Old Feb 25, 2011 | 01:31 AM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
Fred
Fred,
I'm in Orinda also...who did the cat work for you?
Patrick
Old Jul 25, 2012 | 11:07 AM
jack.j.archer's Avatar
2002 E320
2002 E320 (54k miles) Catalytic Converter- Not 4matic, not wagon
I am having a real problem locating a universal catalytic converter that will fit my 2002 E320 (Rears Left and Right). They have the normal problematic noise as described in this post. They are offset and none of the universal models quoted in this and other posts look like they will work. My indy muffler place is saying that they must be offset to fit. They are going to charge me $275 each, plus ~$400 for the splice in work. Seems pricey as I could have, for almost the same price, bought aftermarket parts (entire pipe and two converters each) and installed myself (only a bolt up for the whole thing) -- of course assuming that I can do it myself (maybe), and that my time is free (not usually). Painful.
On another note, how do you find part numbers for anything and everything Mercedes? It makes it so much easier to find parts when you know the part number, but it seems like every site purposely hides the OEM part numbers.
Thanks! I love my car when it is running nicely, and hate it when it is not.
Old Dec 9, 2020 | 11:38 PM
ALida Alvarado's Avatar
C320
Help plz
Don't laugh but how many cats does my C320 have and location plz help
Old Dec 10, 2020 | 01:51 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Wrong forum.
For starters....
c320....probably a w203 or newer. Don't know.
Fill in your user cp info.
Use one of the online EPCs, as Plutoe suggested, on this necropost.
Put in your vin# and then do some research.
Old Dec 10, 2020 | 12:28 PM
190Efan's Avatar
1991 190E 2.3
Will need to know the year of the C320 to determine correct forum section. You can also find it by going back to the main forum page and scrolling down the main forum page until you find the correct section of the forum for your specific vehicle. Be sure to match the year of your vehicle and the model designation to the correct forum section.
