17" wheels from W211 - tire size?
Old Mar 30, 2011 | 12:56 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
Hi all,
I'm looking at some MB 17" sport wheels from a 2003 E320...I think 8" width.
The stock tires on those are 245/45/17's, but I'm wondering if that might be too wide/too much for my 4Matic wagon(2002).
Can anyone comment on whether I should get the same 245's, or if perhaps I can go 235's on the same wheels and still be ok?
Thx.
Patrick
Old Mar 30, 2011 | 01:42 PM
raymond g-'s Avatar
99 E320
i'll let you and others wrestle with the finer details of sizing, but here are
several nice charts to calculate proper size for starters.
note also that your lug bolts are too small for the 211 larger diameter wheel
bolts and ball seat. so you will need to swap out and consider the 12mm
diameter bolt, with 14mm ball seat (search RAD BOLTS and/or OTIS BOLTS)
tire/wheel fitment
my favorite...
http://www.miata.net/garage/tirecalc.html
good one showing side fits...
http://www.1010tires.com/WheelOffsetCalculator.asp
another good one..for MBs, showing reasonable fitments...
http://www.alloywheelsdirect.net/inf.../mercedes-benz
Old Mar 30, 2011 | 02:38 PM
ohlord's Avatar
Yes you can
use the W211 rims.
Use 235/45/17
245 to wide for the fronts.
Per ray you need the special lugs
http://www.radusadirect.com/c=3z2AGo...at-Hex-17.html
$50 a set.
