New car, new problems
Old Jul 12, 2011 | 04:19 PM
E320User's Avatar
Black 2000 E320 4Matic
Hey guys I just bought an 2000 E320 4matic a couple weeks ago, and as driving it I started to realize a couple minor things and one that's apparently major.
Minor
-Rattle in the sunroof/moonroof panel
-Squeak/rubber-on-rubber sound from steering wheel at low speeds
Major
-When the car shifts from second to third gear the car revs before going into third. I'm hoping it might be electrical, but a mechanic told me the transmission had to be overhauled.
Any ideas/advice on fixing these problems would be greatly appreciated, thanks!
Old Jul 12, 2011 | 07:13 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Did you test drive it before buying it?
1) - There is a fix for sunroof rattle - usually the interior panel rattling when fully opened.
2) - There is a rubber boot where the steering shaft exits the firewall. There is a repair for that too.
3) - Transmission slippage usually indicates a problem but anyone can throw in a rebuilt. Have the car's computer scanned for transmission codes and see what turns up. Have you had the transmission fluid level properly tested? That is critical on your 722.6 5sp.
Do some searches on 1) and 2) which are fairly common problems.
Old Jul 12, 2011 | 11:42 PM
E320User's Avatar
Yeaah of course I test drove it hahaha, I realized the sunroof rattling but not the rubber-rubber squeaking on the steering wheel (these were minor issues which I dismissed as I bargained the dealer from 8500 to 7000 taxes included). The car didn't have any transmission problems when I drove it the first week, but after that that's when it started to happen.
I took it to a mechanic whom I asked to check/change all fluids and do a full inspection. Unfortunately that didn't seem to help, so I took it to a transmission shop which told me it needed to be overhauled since the transmission is beginning to slip?
I bought warranty from the dealer which covers up to 2500$, but the other 1000 i'd have to shoulder on my own so I'd still end up with a decent deal for the vehicle even with the transmission rebuild as the car runs perfectly fine otherwise.
But on a good note, i'll search up and fix those minor issues, its good to know that its a pretty common problem so that eases my worries a bit. Thanks a lot for the info!
Old Jul 13, 2011 | 09:53 AM
RichardM98's Avatar
Glad to see you have a sense of humor
These cars have a 'sealed' transmission. There is no dipstick in the transmission dipstick tube just a cap with seal. To check the level correctly, the transmission must be fully warmed up, parked on level ground and a special 'dipstick tool' inserted to check the level. Most mechanics or transmission shops might not have the tool or know the correct procedure. Try a indy shop specializing in Mercedes or a dealer to get a proper check and get the codes read before spending $3500.
I don't think the other problems are serious enough to warrant a DIY so you'll have to search for threads related to the problems but I know I've seen them mentioned here and on Benzworld.
Old Jul 13, 2011 | 09:48 PM
E320User's Avatar
Ah I see, no wonder I couldn't find the dipstick for the transmission to check the level myself. Just a couple questions, what is "indy"? I'm guessing it means a shop specializing in European vehicles? And how would I ask them to check the codes? Is that just the timing for the gear shifts?
Sorry i'm pretty new to this lingo, and i'm not exactly the worlds top mechanic either lol but I'll definitely get these checked out before doing a transmission rebuild, because I heard a rebuilt transmission will only last around 50-60k km's before it starts getting ugly again!
Old Jul 13, 2011 | 11:00 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
"indy" means independent shop, not a dealership.
Old Jul 14, 2011 | 12:31 AM
RichardM98's Avatar
Sorry about the jargon -
The transmission codes are stored whenever errors occur in the transmission operation. Unlike the generic codes any of us can scan with an OBD scanner, they require a MB Star Diagnostic System. All dealers have one and sometimes a very good MB independent shop will have one. If they are indy shops in your area you might try calling around to see if any have an SDS. If the car was recently purchased from a MB dealer they may be able to help.
The 722.6 transmission in your car is very strong and one properly rebuilt should last a lot longer than 60K.
FYI, have you heard of 'limp home' mode? If not, it's a condition that the cars computer can cause so that a problem won't damage the transmission more seriously. Generally, the CEL (Check Engine Light) comes on and the car will not shift gears. The car will drive but you will be limited to one forward gear (usually 2nd) and reverse. I mention this because car problems generally don't fix themselves. Just a heads up in case it happens to you.
Old Jul 14, 2011 | 07:12 PM
E320User's Avatar
Great to know guys, thanks a lot for all the info. I'll be calling around to check/look before I do that transmission rebuild. Also, that's a relief to know that even if its rebuilt it will last a long time, cause I've heard some horror stories about rebuilt transmissions from my friends which had me worrying.
Another thing that's really killing me is the CD player, when I look in the back there is 5 wires, 2 orange ones (the fiber optic wires) and the blue,black,brown wires. Well my dad tried to surprise me by fixing it himself and cut the two orange ones, is there anyway of getting new ones and replacing it myself or do I have no choice but to bring it to Mercedes Benz to get it fixed?
Old Jul 14, 2011 | 07:13 PM
E320User's Avatar
I reconnected the other three wires and tried to test if the audio/radio will turn back on but to no avail, it seems that the orange wiring is needed to complete the series connection in the car?
Old Jul 14, 2011 | 09:21 PM
RichardM98's Avatar
The key phase is 'properly rebuilt'. There isn't any law saying what a rebuilt transmission has to have done to it. Someone could simply pull a 722.6 transmission out of a wrecked car, steam clean the outside and call it a 'rebuilt'. Since warranties on rebuilts are typically short, it's pretty profitable. You generally get what you pay for. A good rebuilt will have been completely disassembled, have any parts showing wear replaced with OEM parts and reassembled and tested by a knowledgeable tech.
As for the CD wiring issues, you might want to post in the Audio/Electronics forum on this site. If the wires you are referring to are part of the car's wiring harness then probably splicing is the only reasonable option. CD changers are problematic, hold only 6 CD's and you have to stop the car to change them. A better solution is to add an AUX-IN cable to the radio and use an MP3 player.
Old Jul 15, 2011 | 01:05 AM
E320User's Avatar
Well I suppose I can only hope for the best if my transmission does end up rebuilt, I'll search around for the SDS tomorrow since i'm off work, and also post that little cd player mishap in the electronics forum and try to get it fixed up. Thanks big time for the help, I'll post my updates on here as I go along!
Old Jul 15, 2011 | 02:17 AM
andy the hun's Avatar
Zaporozec heavily modded 36HP
Take it to the dealer,half hour diagnostics cost only about 60 bucks and you will know whats wrong with it.
Some "indys" I would'nt trust them with my wheelbarrow.
Old Jul 15, 2011 | 12:27 PM
E320User's Avatar
Unfortunately, living in Winnipeg doesn't give me much options and a lot of the indy shops don't carry a SDS so I had no choice but to book it with the Mercedes Benz dealership which will cost 140$ (per hour, lower if its less)
My appointments on the 26th!
Old Jul 27, 2011 | 02:36 PM
E320User's Avatar
Alright I got the car back from the dealership and this is what it says on the sheet they gave me.
A- CUSTOMER STATES THE TRANSMISSION IS SLIPPING FROM 2ND TO 3RD GEAR WHEN ACCELERATING. CHECK AND ADVISE.
SHORT TEST PERFORMED
INDIVIDUAL PARTS OF AUTOMATIC TRANSMISSION:... CHECK
ACCORDING TO FAULT CODE
AUTOMATIC TRANSMISSION SHIFT DELAY CHECK
SUSPECT 2-3 SHIFT VALVE DEFECTIVE CHECKED AND CONFIRMED THE TRANS IS SLIPPING FROM 2-3. HOOKED UP DAS AND SCANNED FOR CODES. NO FAULTS FOUND IN SYSTEM FOR TRANSMISSION. CHECKED FLUID AND FOUND IS OK. LEVEL AND FLUID CONDITION IS OK. TO FULLY CHECK TRANSMISSION MUST REMOVE PAN AND CHECK INTERNALS. HAVE SEEN BEFORE THE 2-3 SHIFT VALVE GOING BAD. RECOMMEND STARTING WITH THE 2-3 SHIFT VALVE AND REPLACING TRANSMISSION FILTER.
and that costs... 644.70$, cheaper than the transmission rebuild, but the guy said that if this doesn't work then i'd probably have to do a transmission rebuild. What do u guys think?
Old Jul 27, 2011 | 05:26 PM
RichardM98's Avatar
First if you are a do-it-yourselfer search for threads on replacing the 2-3 shift valve here, peachparts, benzworld and google. There are several good DIY's on servicing the transmission (ie changing the fluid (special), filter and gasket). Examining the pan for debris is what they are talking about. Some fine stuff is normal but more or bigger indicates problems. Not sure but the 2-3 shift valve may be accessible once the pan is removed. May be one more cover to remove.
Fluid for change is about $120 + $20 for filter and gasket. Price of valve $? and the rest is labor.
This is why I urged you to check it out before throwing in a rebuilt. Even if you have an indy do the work (~ $300-400) you are way ahead of the dealership.
Old Jul 29, 2011 | 12:09 AM
E320User's Avatar
Thanks for all the help Richard, I'm hunting for tools to begin my fluid change
Old Jul 29, 2011 | 01:44 AM
RichardM98's Avatar
It's a pretty easy job and you can save quite a bit over the dealer.
For the drain plug you'll need a 5mm hex socket head. For the pan mounting bolts you need T30 bit. To set final level you'll need the 'dipstick tool' (Part No. 140 989 15 21 00). Available online or from poster Ohlord. Fluid is special (Part No. A001 989 21 03 10) but you can also use (Part No. A001 989 45 03 13 for the 722.9 7 sp trans).
The problem is that only draining the pan gets about 4 liters out of 8 liters (still about ~ 4 l in torque convertor and lines/cooler/etc.). Some people have addressed that by repeatedly draining out 4 l and slowly reducing the amount of original fluid. Pretty expensive approach. Others have detached a cooling line at the cooler and run the engine to activate the transmission pump and force fluid out. Make's me pretty nervous. Fortunately my 98 still has the drain plug on the torque convertor.
Old Jul 29, 2011 | 05:18 PM
E320User's Avatar
Yeah I read about how I can only get 4 Liters out of the 8 drained out, according to Mercedes benz the fluid was still okay so I think just draining 4 is good enough?
Old Jul 29, 2011 | 09:08 PM
RichardM98's Avatar
Actually, MB engineers didn't intend for the fluid to be changed for the life of the transmission. Lately, dealers have been recommending regular maintenance at intervals ranging from 35K to 100K which, IMO, is probably based more on salesmanship than engineering.
The important thing is to check the bottom on the pan for debris. That will give you a good clue of the condition of the transmission.
