Code P0170. Changed MAF, didn't work.
Old Dec 22, 2011 | 04:37 PM
GoldenPimp's Avatar
1996 E320
Engine light came on.
Changed spark plugs, spark plug wires, Mass Air Flow sensor. Light still on.
The car runs fine.
Could it be the o2 sensors?
Old Dec 22, 2011 | 06:17 PM
ohlord's Avatar
Did you clear the code
or just let the new maf self adapt?
Did you buy the maf off of ebay(fake clone) or www.autohausaz.com (real)?
Old Dec 22, 2011 | 06:23 PM
GoldenPimp's Avatar
1996 E320
Not the MAF issue, been turned off by shop and it came back on.
Yes, my MAF is authentic. No cheap Ebay crap.
Old Dec 22, 2011 | 08:56 PM
MBtech1098's Avatar
10 speed bicycle
Have you checked for vacuum leaks?
Old Dec 23, 2011 | 01:10 AM
GoldenPimp's Avatar
1996 E320
No, but I check the attachments everything looks secured. I figured the chances are slim for a leak. But I will do the smoke test.
Anything else?
Old Dec 23, 2011 | 01:40 AM
ohlord's Avatar
Fuel filter
air filter
o2 sensor
Old Dec 23, 2011 | 01:45 AM
GoldenPimp's Avatar
1996 E320
I'll look into it! Thanks!
Old Jan 4, 2012 | 01:38 PM
fatchance's Avatar
E430
Going through the same hunt for the mysterious cause for the very annoying P0170.
I've got a '98 90K E430 and have done the easy stuff so far. MAF (from autohausaz), fuel filter(MBZ), air filter (Mann), 02 sensor, and gas cap gasket.
Don't think it's the spark plugs as it appears to not be the case. I've looked for vacuum leaks, but there doesn't appear to be any. Any suggestions on where to check?
We've had the car since new and this is really really annoying. The car, however, drives well, gets 20 mpg in mixed driving and the CEL only triggers when at idle.
I think the next step is to take it to the dealer for them to hook it up to the STAR diag to see what the cause may be. Fortunately, I have a good friend who's a mechanic at the dealer so at least I know the $$ spent is well invested.
-travis
