W210 LimateControl
Old Jan 15, 2012 | 07:03 AM
kniaz's Avatar
MB E320 W210 98Y
Unhappy W210 LimateControl
How to change the temperature indicator F to C?
Old Jan 15, 2012 | 11:59 AM
n2it's Avatar
Mercedes-Benz E-Class
You change it by way of your computer controls on your steering wheel. Scroll through your menus and you will find it. The sequence is in your manual but I believe if you start on the menu that says, "Settings Can Be Set At Standstill" and then start hitting your "up" or "down" button it will scroll through the clock setting first and then right after the clock setting is the temp indicator where you can change it from C to F.
Old Jan 15, 2012 | 01:06 PM
ohlord's Avatar
He has no steering wheel controls
1998 model. He wants to change the climate control by the radio.
Old Jan 15, 2012 | 01:13 PM
n2it's Avatar
Re: Ahhh...
I did not realize that...sorry man you will have to disregard my response.
Old Jan 15, 2012 | 01:20 PM
kniaz's Avatar
MB E320 W210 98Y
tnx for answer
my mb w210 is 1998y, it have not multi Wheel
How to change the temperature indicator F to C for this model?
Old Jan 15, 2012 | 01:27 PM
kniaz's Avatar
MB E320 W210 98Y
How to change?
Old Jan 15, 2012 | 01:41 PM
CKonstantin's Avatar
W210 E300D
I'm afraid it's dealer only, or indi shop with a proper scan-tool, version coding that you can do manually on the AAC push-button control module does not affect the temperature units.
Dealer should be able to change them on the push-button and Instrument cluster if necessary.
Old Jan 16, 2012 | 08:47 PM
W210 E300D
I confirmed it through WIS, AAC gets the C*/F* setting from the Instrument cluster, which can only be version coded using MB HHT, so you're in for a trip to the Dealer or and Indi shop with a really good scanner.
Old Jun 19, 2012 | 05:49 AM
renault12ts's Avatar
W215 CL500 2005
No need to apologise, that's how we all learn...from each other. Must say though it is easier on a facelift. It also changes the temp display on the dash pod so they match.
