Does this rims fits good on my ride?
2001 Mercedes Benz E-240
I drive a 2001 Mercedes E-240 and I want to know if this rims fits good on it.
They're 19's.
The type of rims that a 2007 Mercedes Benz 5-550 uses.
And if they fit.. What kind of tires should I use?
Thanks.
They're 19's.
Thanks.
98 Brilliant Silver E320 Wagon
19s are probably going to be a problem. Wheels generally get wider as the diameter increases. Also, your hubs use 12mm lugbolts with conical seats. Newer (2003+) S-Class wheels use 14mm so you need hybrid lugbolts for starters. Oh yeah - it will ride similar to a half track!
Administrator
Those appear to be 07-08 E-class sport version rims. They came in 18" OEM, not 19". Bolts are still different between the 2 model series; 12mm vs 14 mm.
1998 E320
Look on the back of the rim
if S class 19's you will have offset issues.
Read the info on the rim it will tell you diameter/width/and offset(et)
you will need all that info before decision made on fitment.
19's look silly and are prone to cracking on bad roads, so even if they fit you want to consider those facts.
With that info then custom lugs will still need to be purchased. All 20 of them!
I have these on my w210 as you can see in the pic, except mine are oem 18's. All that was needed were a set of lugs. Lug= 12mm x 1.5, 26mm Shank, R14 Ball Seat.
