2003 E500 Wheels on 2001 E430
Old Feb 12, 2012 | 03:06 PM
jluu1286's Avatar
2001 E430
Hey everyone just as the title says, I'm planning on getting a set of 2003 E500 wheels and putting them on my E430. I know the size are the same but the bolts are different, besides getting new bolts do I need to know anything else before buying these?
The wheels I'm getting look like this :
http://www.benzworld.org/forums/atta...wheels-005.jpg
The ones I currently have are:
http://www.kenrockwell.com/mercedes/...l-KEN_7994.jpg
Also, what do you guys think look better? Should I go for it or not?
Thanks!
Old Feb 12, 2012 | 04:40 PM
illest's Avatar
w210 AMG or S213
the wheels look nice and should fit without a problem, just dont pay too much. People are upgrading their wheels all the time so you can get some good deals if you are willing to look. I picked up a set of 18 inch w211 sport wheels with newish conti tires for $600.
Old Feb 13, 2012 | 03:18 PM
jluu1286's Avatar
2001 E430
Illest,
Thanks for the fast reply and opinion!
I was thinking about trading my current wheels for his with in addition to maybe $100-$200, does that sound like a good deal to you?
Also, don't the W211 have a different bolt dimensions than the W210?
Lastly, do you have a before and after picture of your car?
Thanks again!
Old Feb 13, 2012 | 07:22 PM
CKonstantin's Avatar
W210 E300D
The bolts are slightly larger in diameter, but as to their length it can vary depending on the model of the mag just like ours(w210).
Good luck.
Old Feb 13, 2012 | 07:28 PM
jluu1286's Avatar
2001 E430
Good luck.
CKonstantin,
Besides changing the bolts that's all I need to worry about right?
Also, bolts are not too expensive I assume.
Old Feb 13, 2012 | 07:47 PM
W210 E300D
If you buy originals they're pretty expensive(about $5 each which adds up to $100+tx), and I'm not sure how trustworthy are the chinese bolts from eBay...
As per my research the center(hub) hole is the same, check the off-set just in case but it shouldn't be an issue, so the bolts would be your main worry, I guess, check if you can reuse yours, otherwise you'll have to improvise.
With MB the biggest problem is the bolts have to be just right if they're too long they'll rub against the brakes in the back, if too short - well you can guess what will happen. As to w211 vs w210 bolts, I'm not sure if the threads are the same or not, I know that the 211 use 'new' style bolts which are thicker than ours not sure if it's just the stem or the threads as well though...
Old Feb 13, 2012 | 08:13 PM
jluu1286's Avatar
2001 E430
I see, I'll confirm with a wheel shop what I need once I get the wheels and I'll provide an update on what we need to go from W211 to W210 wheels.
Thanks again for the help!
Old Feb 13, 2012 | 08:33 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If you need bolts radusadirect.com USA is a good source.
Old Feb 13, 2012 | 08:49 PM
raymond g-'s Avatar
99 E320
your 210 uses 12mm with 12R dia bolts. the 211 uses 14mm w/14R ball
so if you follow through and purchase the 211 rims you will need to purchase
12mm bolts with hybrid 14R ball to fit the rim's 14R ball seat. should run you
about $3 each from RADUSA/Otisla
the length of the bolt should be long enough to extend out the back of the rim
by .5 to .75"...no more or it may cause damage.
one should attempt to be cheap and use the 12mm 12R lug bolts as the bearing
surface of the ball will not allow for sufficient bearing surface within the 14R
seat.
Old Feb 15, 2012 | 09:42 PM
illest's Avatar
w210 AMG or S213
There are some pics of what the wheels will look like here
I have not installed mine yet because I am lazy. Once you install them make sure to keep a set of your old lugs in case you need to mount your spare.
Old May 19, 2012 | 12:44 AM
jluu1286's Avatar
2001 E430
Hey everyone,
Thank you so very much for all the great replies!
I actually worked out a deal with a close friend to trade his 2003 E500 wheels for my 2001 E430 wheels.
Based on everyone's reply, I need to get 12mm bolts with hybrid 14R ball. Can someone confirm this before I go through with this trade?
Also, as for my friend with his 2003 E500, how will he mount my old E430 wheels?
Would he also need to buy a new set of bolts?
His wheels look like this:
http://timeswheelsforyou.com/vimages...J23A302114.jpg
Thanks again everyone!
Old May 19, 2012 | 01:05 AM
raymond g-'s Avatar
99 E320
whoa.....your friend wont be able to fit your rims with 12mm diameter bolt/holes
onto his car which uses 14mm bolts.
you may be able to buy bolts with 12mm diameter bolt and 14R ball seat....
but your friend wont be able to source 12R ball seats with 14mm diameter bolts
as they don't exist.
Old May 24, 2012 | 09:36 PM
Kid69Nice's Avatar
1998 Mercedes Benz E32O Wagon Named "Rival"
Smile
Thanks!
They'll look great. I've got those rims right?
Old May 25, 2012 | 08:28 PM
Bucs23's Avatar
2001 E320 wagon
Thumbs up LOOKING GOOOOOD
Man that is THEEEE clean look I'm looking for. Congratulations tht looks real good. Do you mind me asking where and how much you paid for the lug bolts? Where did you get them from?
Thanks, congratulations gain. Well Done!
Old May 26, 2012 | 06:11 PM
Kid69Nice's Avatar
That's how I bought my Benz. I'm not sure how much was paid.
Old May 26, 2012 | 07:15 PM
Bucs23's Avatar
2001 E320 wagon
Yes, I realized now I confused you w the original poster. Anyway I too have a wagon and that is the exact look I'm looking for. Hopefully I can sell my 19"s and buy the E500 wheels you have.
Thanks for posting the pics.
Old May 29, 2012 | 02:30 PM
jluu1286's Avatar
2001 E430
Well, after talking it over with my friend...It would cost me more to take his wheels and get a new set for him than just buying my self a used/new set...
Now I'm currently interested in the AMG monoblocks since it seems cheaper to go with a used set haha...
I'm wondering if I can fit these on my car and if so, what is a fair price to buy this off him for?
http://atlanta.craigslist.org/nat/pts/3044676066.html
Also, I know this isn't the 18in from our model but I can't find anyone with them.
Will the 17s still look good on my E430?
Old May 29, 2012 | 02:48 PM
desired_speeds's Avatar
2007 SL55 AMG
17in. monoblocks look weird on W210s IMO
Old May 29, 2012 | 02:52 PM
jluu1286's Avatar
2001 E430
Yeah I thought so...Sigh hard to find a new set of rims that won't look ridiculous on my car haha
Old May 29, 2012 | 03:13 PM
2007 SL55 AMG
I have two sets of rims for sale listed in my signature. Check them out.
Old May 29, 2012 | 03:17 PM
Bucs23's Avatar
2001 E320 wagon
Maybe we can all help each other out...
I do have a set of 19"s just came off my W210 wagon. If I don't sell them this week I could meet you half way if you were interested. Please check them out on the link below.
https://mbworld.org/forums/wheels-ti...s-900-obo.html
Old May 30, 2012 | 12:07 AM
ohlord's Avatar
You
don't want 19's
Old May 30, 2012 | 07:13 AM
Bucs23's Avatar
2001 E320 wagon
Thumbs down Different folks ...
Originally Posted by ohlord
don't want 19's
Never had a problem w 19"s before. Sold my MB's 19"s to replace them w aftermarket ones for the looks only. Never a ride issue. Then again I have a wagon, so cross country rallies are not part of our daly driving. On the other hand, the 42 mile daily commute felt very confortable on the 19"s specially on the tollway.
Old May 30, 2012 | 09:13 AM
illest's Avatar
w210 AMG or S213
Finally got my 18's on.
Old May 30, 2012 | 10:01 AM
jluu1286's Avatar
2001 E430
Illest, I'm TRULY jealous of you right now! They look great on your car!
If I may ask, how much did you pay for the set?
