anyone cut springs in the bay area?
Old Mar 1, 2012 | 07:59 PM
siopaolover's Avatar
1998 E320
i'm looking for someone who could cut springs in the bay area that won't charge too much. any info would be greatly appreciated. thanks!
Old Mar 1, 2012 | 09:10 PM
tc1728's Avatar
sonicMS in Mt. View has cut springs before. TC
Old Mar 1, 2012 | 10:20 PM
1998 E320
o thanks. they were charging me $300 to swap springs though, so i'm not too sure if it would be reasonable
Old Mar 2, 2012 | 01:57 AM
raymond g-'s Avatar
99 E320
all it takes is a friend with a compressor, an air tool with an abrasive cutoff
wheel, and about 15 mins of work.
but, you should probably spend about 30-60 mins measuring and marking and
double checking your work. i used a laser measuring tool to help determine
and pinpoint the vertical drop of 1" and where on the coil the cut should be.
secure the spring in a large vice and carefully and firmly cut. keep heat
build up to a minimum
Old Mar 4, 2012 | 06:32 PM
1998 E320
hmm now i'm considering not cutting them... does it get bouncy after they're cut?
Old Mar 4, 2012 | 07:34 PM
track_warrior's Avatar
Like The Stig
Dont do it, its not a honda please stop!!
Old Mar 4, 2012 | 10:12 PM
Kayos77's Avatar
2012 ML63 with P30 package
I couldn't agree more with you!!! Step up and spend the money to do it the right way
