96 E320 4 Speed Trans Slipping
Questions I have are…. What type of fluid I should use?? After reading posts here I’m not sure if I should use MD fluid.. (will they give me 7speed fluid ) or if I can use Mobil 1 full synth? And does anyone know for sure if the 96 has a drain plug on the Torque Converter? And can anyone tell me what model Trans is in my car?
Car seems OK now but I don’t want to drive it to work on the skyway and risk getting stuck in traffic.. the tow home would be $$$$...
Any thoughts / replies are welcome…
Many Thanks !!
Dave
If it is running fine now you either have a vacuum line leak thus the egr code or the trans needs to be adjusted. suspicion would lead one to think since you have no slipping issues now some line is loose or brittle and leaking.If you DIY get out the flashlight and start searching,if not take it to a good indie shop that works on older MB's and explain what happened and when and have them examine it.
In the future just drain don't flush the trans.
722.329
