1998 E320 EGR valve / MAF
2005 E320 4matic wagon
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Anybody know if these cars have an EGR valve or device? I just replaced one on my aging 2005 Honda van and it made a world of difference. Where is it found, removed please?
Also, when cleaning a MAF, the spray can says to spray it on hot wires. Never done this before, does that mean the car should be run first and the MAF wires are already hot? What's the procedure for cleaning?
Yes it has an
EGR valve won't affect performance. If you ever get a p0400 code you clean it and the tube to the intake.
Maf cleaner CRC brand follow the diy for cleaning on benzworld.org w210 diy forum
Unless you have the typical codes for maf out of range little to no need for cleaning anyway,and if you do get those codes cleaning is a stop gap till r/r the unit.
Time to change your trans fluid and filter though, I can see from here![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
