01 E430 Horn's ineffective sound
The horn just has a weak, low sound (sounds like borrrrrnn). I also have an 85 300D whose horn is much louder (sounds like PEEEAAATT!!).
I have a similar problem.... Sometimes my horn sounds fine and many other times sounds like only one of the two horns are working....
I was thinking of removing the horns from a 300D. Those were SWEET!
If I was replacing mine, I'd get double air horns - they sure scare the sh_t out of the fxcking inconsiderate drivers.
Air horns are fine, but they are too slow to spool up for my likes. (I'm an instant gratification type of guy) Try the Hella replacement horns. They are about 118 decibels and will get everybody's attention, . . . and are painted bright RED.
The Hella 85115 Superhorn (Made in Germany)
Hella Horns
I have a 1999 E-Car and its easier to going in through the space between the right hand high and low beam (after removing the rubber trim ring seal) to allow access to the lower horn.
