Ignition switch came loose. Help!!
I have searched.
Sorry, but I have not found instructions I can apply to my situation.
2001 W210 E320 RHD
First: My ignition switch (Electronic type) assembly has come loose and dripped into the dash. The outer surface bazel just fell off.
I need to position the assembly back into place.
Please tell me how to get at it. How is it held in place?
I believe i will need to remove the driver's underdash panel.
Please tell me how.
Are there any other panels or items that will need to be removed?
Please explain.
Thanks,
Joe
OK. I got it done.
I was very concerned about using anything made of metal.
I got hold of a piece of nylon fishing line. Quite a thick one.
I then formed a loop, pushed it through the hole and looped it around the switch.
I then pulled the switch out towards the hole.
I held the switch at the edge of the hole.
I then passed the key through the bazel and put the key into the switch.
I turned the key to position one to lock it in place.
I then removed the fishing line while holding the switch with the key.
I was then able to screw the bazel back onto the switch.
With my thumbs I was able to tighten the bazel.
Problem solved.
As a note.
There was no warning. So from now on, I will be checking the bazel for tightness.
There is a tool to tighten the older key type switches.
This bazel is smooth.
She played with the EIS for a few minutes and could not unlock. She finally mention to me there was a problem.
I gently inserted the key. No problem drive the vehicle into the garage at home. The next day drove surface streets to the shop about thirteen miles from home.
