1995 E200 starts but does not crank
Here is the issue: As the cold weather came, the car would not crank anymore. Had this issue last winter, and I did bypass the starter relay, mounting another start button which takes + 12 V from the radioset and gets it directly to the starter's relay. Also, the green and red lights from the central mirror are flashing alternately 10-20 seconds after the car starts running.
I was thinking that the alarm has something wrong as long as it blocked the cranking. Regarding the alarm, since I've got the car (20.000 km ago) I can only start the car after depresing the key twice (close & open the doors) if the red LED on the dashboard gets on (shortly after the initial door opening).
If somebody encountered this issue, please give me a clue, it is bothering alot.
Thank you for your time
Stefan
1995 E200 automatic, 111.942
ps. have changed key's batery
Soo, I want to make the car act normal, to be able to be ignited with the key, not a bus buton
.Hope I made myself clear.
And thank you for taking time to answer.
Stefan
I mean the bendix relay, on the starter. Actualy I can spin the engine with key in pos. 1 (as long the radio gets 12V).
vin is WDB2100351A005364
it looks like DAS authorize the start procedure, because I do start my car. So, maybe the chance is only the alarm's starting protection is bypassed.
As I recall, the diesel should be 2200cc, don't it?
Have a perfect day.
Stefan
Things are still confusing, ? you did provide the VIN, yet you say you drive a 1995 E200 Yes, engine 111.942. I could not check the datacard therefore additionally confused as to whether you have the electronic key or metal key---yet your first post said you changed key batteries--- I did change them once. Key is metalic, resembles a swiss knife.
With all the confusion I am assuming you have the EIS(electronic key). That being he case the DAS is checked twice.
First when you put key in---if ok the steering lock is released. I feel like the release is mecanic, clasic style.
Second when you move to position 2-the key info is checked with the key data in the ECU---if ok the car is released for starting with a CAN message to the K40
The only fuse in the DAS circuit is fuse 9
Although I have not sen the car, this is my leap of faith diagnosis.
Check fuse 9!!
Hopefully you have not changed the ECU!! No way
When you put the key in---the steering lock is released and you can move the key
You can then move the key to the starting position----the starter(K40)relay is energized, but the car does not start.
It does not start because the either the ECU was not energized oh yes, it is energized, car starts imediately when the bus button is depresed. or the ECU does not send a CAN message that the DAS is correct. In these cases there is a fault but it is a B type(non EUR) fault that will not light up the dash. I do not know even if this year has a CEL light, never seen it on the dasboard. Carsoft told me about some codes, but never a CEL light.
The only way I know how you could possibly check all this is via the MB diagnostic system DAS Xentry go to and indy and have him do a quick test and all the faults will be apparent----it is either bad wiring, fuse or the EIS or EUC are faulty.
That is my take. Good Luck
Yours, Stefan
I'm not 100% sure the problem in your car is this, but is just a point. I experiment the exactly same issue with the mirror leds and no stat.
Just check and i hope you can solve the issue
Fabio Daniel
