changing tranny fluid
the bushings that are on the transmission, are there any??
-s-
You may want to change the shifter bushings, but I wasn't aware that there were any issues with that year car... but then certainly that doesn't mean there isn't.
-s-
that Wears out and causes the Shifter to Rattle.
Its on the Drivers side of the trans
BTW Please make sure you drain the Converter!
And Replace the Drain Plug crush washers!
You Will Need a Dip Stick and Tamper proof replacement cap
Use Only MB Fluid!
Good Luck!
Is it likely for a weekend warrior with modest tools to do the work at home?
