Climate control
Old Jan 11, 2013 | 01:59 PM
skj0lsvik's Avatar
E220 W210
Climate control
Hi all
I'm not able to turn the EC off, no matter what I turn on or turn off the light won't come off... Will this mean that the system is out of gas?
Cheers,
Sondre
Old Jan 11, 2013 | 07:07 PM
skj0lsvik's Avatar
E220 W210
Thanks for the quick reply, I'll have a look into it tomorrow It 's not like I miss it, I live in Norway and since it's winter it'll rarely get warmer than 0 degrees Celsius... :P
Old Jan 17, 2013 | 10:17 PM
Mr.Billyd's Avatar
E300 D
Check your codes on the climate control unit. It's easy to enter the diagnostics of this unit. If you have a code for the clutch ( like I did your hosed)
I got the code for the clutch which set the EC light.
By the time it forced my system off, the compressor seized up.
I fixed mine my self and it has been working great in the AZ desert.
Luckily I got my compressor from TX for 250$
Good luck.
Bill
Old Jan 19, 2013 | 02:47 PM
skj0lsvik's Avatar
E220 W210
I do suspect it may be out of gas but I don't know How can I enter/check for faulty-codes on my climate control unit?
Cheeers,
Sondre
Old Jan 20, 2013 | 03:54 AM
skj0lsvik's Avatar
E220 W210
Thank you so much! I'm heading out to do some diagnostics ) Hopefully there's nothing too serious...
Old Feb 10, 2013 | 11:40 AM
skj0lsvik's Avatar
E220 W210
Originally Posted by Plutoe
There are two parts---reading actual values and reading faults. You need both to fully understand what is going on.
READING ACTUAL VALUES:--------AC must be running to retrieve actual values!!
Ignition---position 1
Press the auto button and set temps to 72F or equivalent C
Press the Rest button for 5 seconds or more
The left side of the display will show number"1" and a value for In car Temp
Then press Auto again for the next number and corresponding value
Keep pressing and writing down the numbers and values till "12"
To end the process press Rest----you are half way done!!
READING FAULT DIAGNOSIS:
Ignition in position 1
Set Left Temp to LO
Set Right Temp to HI
Within twenty seconds simultaneously press the rest and EC for more than 5 seconds
The screen will flash "dl R"
Now press the right Auto button one at a time until all faults are displayed and recorded
All faults must be read out before they can be cleared.
To clear all faults press both auto buttons for more that 2 seconds and a "d" will be displayed on the left and "FF" is displayed on the right
Now go back and reset you cabin temps---ignition off------end of test
Good Luck and after clearing the faults there will be no red light on the EC button, but will return if you do not fix what is faulty.
In your case that will be late summer, Oh well
I didn't manage to do the last part(look at marked text in quote..). But I got a wide variety of numbers when I did the first part(read actual values). Not sure what they mean though, if I'll post them here some of you might understand something?
Old Feb 11, 2013 | 02:32 AM
skj0lsvik's Avatar
E220 W210
Sweet!
Here it goes:
1 - 05
2- - 02
3 - 28
4 - 29
5 - 07
6 - 36
7 - 02
8 - 06
9 - 05
10 - 1.8
11 - 2.3
12 - 4.1
The next after 12 was 20 with the value 0.0
Cheers mate, youre helping me big time )
Old Feb 11, 2013 | 06:50 AM
skj0lsvik's Avatar
E220 W210
What does these values actually mean?
Well, I'll gotta give it a second go then. I'm not too worried about losing the functionality of the AC but it would be nice to know what's wrong with it...
Old Feb 11, 2013 | 08:15 AM
skj0lsvik's Avatar
E220 W210
Sorry mate, I didn't notice that you had noted the meaning of every number in my quote. But thanks anyway! I'm out to try again now :P
Old Feb 11, 2013 | 09:47 AM
skj0lsvik's Avatar
E220 W210
It worked!!
Errors I got looked like this:
E61 - 234
E61 - 416
E61 - 241
I bet this gonna be expensive :P
Old Feb 12, 2013 | 03:26 AM
skj0lsvik's Avatar
E220 W210
Wow! Thank you!! This wasn't bad at all, I do not care to much about the AC but I will get it fixed anyway. Nice to get things sorted... I do not see any hints to having a bad coolant pump in everyday driving, the car is always "cold" (beneath 80'C). But if the codes say so I should probably change that too.
What is the main purpose of the sun sensor?
Cheers Plutoe! You're a great addition to this forum
Old Feb 12, 2013 | 04:42 PM
skj0lsvik's Avatar
E220 W210
Yes, I am aware of that. I just ment that if the coolant circulation pump were really, REALLY bad my engine coolant would most likely get hotter than normal and even boil!?
Old Feb 13, 2013 | 01:54 PM
vishanthram's Avatar
2007 SL550
The main purpose of the sun sensor is to detect the sunlight inside the cabin and increase or decrease the fan speed. It is located in the dash board near the windshield, the failure of that will not affect any of your ac function.
Old Feb 13, 2013 | 01:55 PM
2007 SL550
actually this exact same thing happened to me in my 1999 E430 when i first bought it and i did the test and took to shop, they clear codes and refill freon and it was fine after that.
Old Feb 13, 2013 | 02:45 PM
skj0lsvik's Avatar
E220 W210
Ah, more like a trouble-maker this sun sensor then? I'd like to control it myself at all time
Yea, looks like it's time for a quick stop-by the local workshop to get it filled. Hopefully it's just empty...?
Old Feb 13, 2013 | 05:57 PM
skj0lsvik's Avatar
E220 W210
Ah, it surely plays a bigger role in controlling the temp than I thought. But I am rarely bothered with extreme warmth here up in cold Norway so I'm not sure if I should bother change it...? Th AC-system will be fixed though!
Old Feb 20, 2013 | 12:50 PM
Gcarpenter's Avatar
03 C32 amg, 2002 ML320
I tried, but cannot get the second test to work. I followed the direction exactly, no matter how long I hold down the EC and Rest buttons, nothing happens on the screen.
Old Feb 20, 2013 | 05:23 PM
skj0lsvik's Avatar
E220 W210
Had the same problem, try having the hi and low temps opposite of what the directions tell you to. It worked with me that way
Old Feb 20, 2013 | 07:52 PM
Gcarpenter's Avatar
Thanks, I got the first test to run without problem. Hope this works for the second test.
Old Mar 20, 2013 | 01:39 AM
khangee's Avatar
1990 300SE, 97 E420, 2001 E430
MY 2001 E430. I get one E61 416 error code. Does that mean Coolant circulation pump gone bad. I do hear whising sound coming from center vent.
Old May 11, 2013 | 02:17 PM
RC46's Avatar
97 Dodge Ram 4x4
Help please
AC not getting cold and EC light was on..
And In Vegas no AC...NO BUENO!
Here are my codes.
29
25
30
30
28
38
02
26
05
2.6
2.8
4.2
EB1 234
EB1 241
E FF
any help would be appreciated.. And if you are in Vegas soon I will buy you a beer, or 5..
