HELP!! acceleration defective!!
and recently, like about a month or two ago i have noticed that sometimes at a stoplight or turning and then accelerating or even at rolling and acceleration that when i press on the gas the engine revs up to 3,500 rpm and then kinda acts like a turbo just rams it way to 6000 (red line). It is like the car is sensing the gas pedal at full throttle like a good 15 seconds after i full throttle it
!! It is very weird, so i took it my local import auto shop and they said it could be the throttle sensor. So before i repair something that might not be the problem, i wanted to ask for opinions. So help me figure this out, please?
Do you ever get warning lights when this happens?
and now i am like 'this guy is crazy and probably high or drunk'
even if you invite me to your shop i will not come to your shop. Thx though and i must ask, are you on some kind of medication old man?? How the hell do i know if you are a guy or a girl and how the hell do i know if your name is Victoria or bob
!! What the hell is wrong with you??
Failed to point out in another recent post about P0105 code that a MAP sensor code is not the same as A MAF sensor code(good luck repairing a MAP sensor related code by replacing the wrong part entirely)
.So obviously has not a clue about Mercedes related diagnostics.
Manifold Absolute Pressure sensor issues would be common knowledge to any mercedes mechanic with a modicum of knowledge and MAF related codes and circuit failure codes could be called to mind in a real Mercedes Tech or good Diy'r in their sleep. . That is why he was banned from benzworld for life and eventually will be banned for passing out bum(costly) information on here for life (or longer)
Victoria may or may not exist. That may be a screen name he uses on some other forum
That is yet to be determined.
Ohlord
Plutoe knows more than at least one member on here!!!
