Clicking noise on W210
Anyways, I have a 1996 w210 and was wondering what might be the issue with it. When I give it a cold start, I hear clicking from the engine and it matches the revs on it too (revs go up, clicking goes faster, visa versa). It also went away once I hit 80C. I didn't mind it at first... until it began to get louder and it's at a point where it's not going away. All I can say is the belts are fine and I change engine oil frequently. What do you think it is?!
I have been reading threads about a constant tick tick tick that my W210 99 E430 was having. Lots of threads lead me to the (mot) pictures above which does have a fast clicking noise until oil warms up, but isnt that loud. I also had others tell me it could be valves. It sounded like it was coming from my injector area on my driver's side. I removed the fuel rail and inspected and cleaned the injectors. I changed all of my vacuum hoses and oil cooler rubber hoses. I found vacuum lines completed destroyed. It is good to check those. Pelican Parts has a lot of technical data on where to check these. None of this solved my ticking noise!!!! Turns out my static tick tick tick noise was voltage loss from at least one of the coil packs or plug wires. I removed all 4 coil packs on the driver's side and everyone had cracks in the housing. I used 100% silicone on each one and cleaned connections. I have no ticking noise any longer!!!!
