Seat SRS signal
The seat comes out really easily, four bolts on the floor and onr for the seat belt.
Disconnect all plugs and lift seat clear.
I followed the lead from the yellow plug to where it went through a hole in the metal base of the seat. It was the classic cause, the wire was chafed and actually the white wire was completely severed.
I cut the cable tie and managed to cut my finger on the metal base...that's how sharp it is and WHY the sensors fail.
I removed the yellow socket from the carrier, snipped the lead about 4 inches from the socket...and then soldered the emulator to the three wires...white to white, brown to brown and red to red. It was that simple.
I re-installed everything...turned on the ignition...all lights stayed on...but then went off after the test period...hallelujah...it worked.
I suppose I could have fixed the wire...but there was no room even with the seat out.
In short find a upholstery guy
BTW mine had a split in the seat harness and it also had random SRS light
*There is also a possibility that the air bag could go off if someone is sitting int he passenger seat. I think I read this on benzworld. Something to do with malfunctioning of the SRS system. I also read the reason why there is a SRS system on the passenger seat and not the driver is due a baby seat sitting on the passenger side (Germany?). Food for thought
This is also why there isn't a SRS box in the driver-side. Edit:
Here's the link
http://www.benzworld.org/forums/w210...placement.html
You don't need one on the driver's side because...when the car is moving there will always be someone sat there.
Armani
