Fixing up some minor cosmetic damage
2002 W210 E320
My car has a fair amount of rust on the brake calipers. Would it be okay to paint over them, with a brake caliper painting kit? I've heard from some people that this stops heat dissipation, and others say this is ridiculous. Also, what can I do about the headlamp cases (shroud?) being extremely fogged/translucent? I tried buffing them out but this did nothing. Final question. Is it common for the check headlamps warning to pop up and then go off again. It seems when I hit a bump the light goes on, even though I've confirmed there is no issue with the lights functioning.
The headlight issue is rather common, read this thread: https://mbworld.org/forums/e-class-w...hat-works.html
It is okay to paint the rusted calipers, but I would def. remove the worst rust using a drill with a
. And yes, the rust will come back after some time... Unless you buy a rebuild-kit and sandblast them properly!
And final question, the check headlamps warning is also EXTREMELY common. Things you can do is to wrap the bulb-terminals with alu-wrapping. I did this on my brake-bulbs, it worked with mine
2002 W210 E320
And final question, the check headlamps warning is also EXTREMELY common. Things you can do is to wrap the bulb-terminals with alu-wrapping. I did this on my brake-bulbs, it worked with mine![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
'99 E430, '05 ML500, '15 GLK350
You can safely paint the calipers.
It is not uncommon to get occasional "lamp defective" warnings caused by iffy connections in the bulb sockets, esp in the rear. Electrical contact cleaner can help.
Foglights will fail after a while, and the license plate bulb can also trigger the warning.
