Door locks behave funny
1998 E300 TD
It used to lock all four doors with one press to the remote. Now I have to push four times, each press will only lock one door? What gives? Thanks
PS: the E300TD 98 did go to the shop before this happened.
What can't be right!!
PS---Are you aware that you ignition key has batteries??-------look in your owners manual
1997 E420
The signal strength of the key fob wont effect the actual individual solenoid's function, it merely says lock the car or unlock the car. do the door lock solenoids attempt to move the door linkages it only sends a brief pulse to actuate, you might have to use some lithium grease on the cables and linkages to move freely again. or the motors may be wearing out.
Do they all unlock on command?
1998 E300 TD
More testing indicates the front doors responded concurrently, but the rear doors independently. Sometimes, it took two/three tries to close.
1997 E420
Or like the other guy said, you can keep changing the key fob battery? LOL
1997 E420
You will have to pull the door panels off, roll the windows up all the way carefully pull the plastic membrane aside, don't remove it all the way.
and you should be able to gain access from there.
