1995 E320 Wagon rear suspension HELP
I would like to get the original load leveling suspension back in the car ASAP. The lines for the load leveling system are blanked off in place so I thought I would find a set of the used Merc load leveling shocks and install them.
Can anyone provide me with a procedure on how to bleed out the load leveling system? (I did not find one using the search function) Any advice for trouble shooting would be greatly appreciated.
Matt
Looking forward to hooking the leveling rams and see what happens when I start it up.
I ordered a set of used (ebay) and was told that part number 124 320 25 13 with a big number 8 on the side would work. I have the car up on jacks pulled out the stupid aftermarket shocks then found out that the new ones did not fit. They are about 50mm too wide to get in the rear lower control arm. I could grind them down to fit but it's a 400 dollar one way modification.
Pressure is added to the struts to level the back when weight is added, and released when the added weight is removed.
You might check out benzworld dot org or peachparts dot com, as there are many folks posting about wagon rear suspension and SLS issues. The factory service manual is also available at benzworld in a DIY sticky.
Anyone have a source for the replacement hydraulic lines?
Now what? Accumulators?
The ride is quite harsh/hard when the cars are empty but with some weight in the back it should feel softer,they are designed to carry some weight
