1997 E420 - Rear roller sunshade stuck in up position
Old May 11, 2014 | 01:04 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
My rear roller sunshade is stuck in up position. Do any one knows where is the fuse for rear roller sunshade? Or have wiring info that I can get.
I went through 3 fuses area in the car, but I don't find fuse marked for rear roller sunshade. Please help.
Old May 11, 2014 | 06:26 PM
hadam's Avatar
The VIN is WDBJF72F9VA544302
Old May 11, 2014 | 07:16 PM
hadam's Avatar
Thanks. Yes I checked the fuse and it is good. But anyway I replace with new one. But no luck, sunshade is not working. If there is any other idea or wiring diagram will be greatly appreciated.
Only reason I was trying to bring roller sunshade down was that my 3rd brake light is not working, I wanted to change the bulb.
I always leave my roller sunshade up, but one time I want it to go down so I can change the bulb on 3rd brake light, it is not moving.
Old May 12, 2014 | 01:15 AM
raymond g-'s Avatar
99 E320
is there a reason why you rejected fuse #12 as stated on the chart?
(oh sorry, asked and answered. it was late and i had a huge Mothers day dinner. )
Old May 12, 2014 | 07:22 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
On mine, the sunshade was intermittent. It seemed to be temperature-dependent. In any case, I could often get it to move by holding the switch down (helper) while pushing-pulling on the shade to give it some assist.
Old May 12, 2014 | 11:28 PM
hadam's Avatar
Thank you all for your input.
Late yesterday I manually played with the roller track to see it may make it lose and work. But did not work.
Finally clean the switch contact and it is working again.
Just to be safe, I am keeping the roller rear sunshade in down position.
Next question, any one know how to open cover on 3rd brake light? I have to change the bad bulb in it.
See photos of 3rd brake light. Please help.
1997 E420 - Rear roller sunshade stuck in up position-2d3f40c4f41dcc5413821afbd998ac75.jpg
1997 E420 - Rear roller sunshade stuck in up position-d076d1e5ed26fbd45f33e980cf433d0a.jpg
Old May 13, 2014 | 06:59 AM
Hirnbeiss's Avatar
The definitive reference:
http://www.benzworld.org/forums/w210...pair-97-a.html
Old May 14, 2014 | 07:55 AM
hadam's Avatar
All fixed. Thanks Plutoe and Hirnbeiss.
Week befor last week this forum saved me also $600 on my W221 (2007 S550) on door control module by telling dealer to reflashed it rather then replacing with new one.
Thanks again all.
Old May 27, 2014 | 06:17 PM
gqmagic's Avatar
96 SL500, 97 E420
I'd rather have mine stuck in the up position.
