code: P1227
Old Jun 30, 2014 | 07:19 AM
cm60k's Avatar
Question code: P1227
Guys,
Does anyone know about code: P1227..?, it appears with with my friends "2000 W210 E320 & W208 2001 CLK55",
with some research, it could be a part of air conditioning, called:-
"Exterior distribution shaft position sensor",,
what & where this sensor...??
ZAYED,,
Old Jun 30, 2014 | 12:50 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
If the car is starting when cold but not restarting when hot, this may be referring to the Crankcase Position Sensor. Found on most cars at the back of the engine near the flywheel. On the W210 V6 it's on the left side. Not visible without a mechanics mirror. Plenty of online DIY's for replacement.
Old Jun 30, 2014 | 04:46 PM
cm60k's Avatar
2000 E320 VIN #: WDBJF65J1YB028508
2001 CLK55 VIN #: WDBLJ74G71F170654
ZAYED,,
Old Jun 30, 2014 | 07:00 PM
cm60k's Avatar
I didn't get your point mate..!
P1227 shows up with 2 cars, it called "Exterior distribution shaft position sensor",
http://www.benzworld.org/forums/w210...c-light-2.html
http://www.peachparts.com/shopforum/...7-problem.html
ZAYED,,
Old Jun 30, 2014 | 07:18 PM
RichM's Avatar
2 2001 E320s, 2005 E320 4Matic
This is a code most related to Diesel engine cars. As the cars you refer to are gasses, this should not be a relevant code. Not sure how you proceed to find a solution.
Old Jul 1, 2014 | 12:34 AM
cm60k's Avatar
Ahh, WASTE YOUR TIME..! why, nobody forcing you to answer anything..,
we believe you know your stuff very well, but that doesn't means you're more knowledge than others..!(?)!
btw; i went to the dealer, and they said in some cases; P1227 appears during to malfunction of the sensor inside climate control unit(part of the unit circuit),
i replace it with another unit, P1227 NOT show-up again, and A/C working as it should...
Thankss for reply & help fellows
ZAYED,,
