need help with my e420
Old Jan 22, 2015 | 07:47 PM
trich2121's Avatar
97 e420
K so I bought a 97 e420 a few months back has 157k on it the other night the battery was dead so I jump started it and then the rpms started bouncing between 1000 and 1300 and even if I put the gas pedal to the floor the rpms will not go over 1300 I have tried driving it and same thing just bounces hitting 1300 and back down could this be from bad gas or the mass airflow sensor or throttle body needing cleaned?? Please help thank you
Old Jan 22, 2015 | 10:10 PM
trich2121's Avatar
97 e420
help
Also got told it could be because a bad battery is that possible
Old Jan 23, 2015 | 11:49 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Jan 23, 2015 | 12:04 PM
RichM's Avatar
2 2001 E320s, 2005 E320 4Matic
Yes.
Old Jan 24, 2015 | 08:38 PM
trich2121's Avatar
97 e420
El please
K so after replacing the battery and trying to get it going my e420 still won't go over 1300rpm throttle is stuck at 33% is there a fuse that can be bad or anything of that sort
