srings problem
Old Apr 28, 2004 | 11:02 AM
mastakamasutra's Avatar
HONDA ACCORD
DELETE POST PRIVACY
DELETE POST PRIVACY
Last edited by mastakamasutra; Nov 18, 2014 at 04:13 PM. Reason: DELETE POST PRIVACY DELETE POST PRIVACY
Old Apr 28, 2004 | 11:58 AM
rob_fed's Avatar
W204 C300 2010
Are you refering to the upper spring mount? Where the the spring pad and spring fit in? If so, it sounds like the upper mount has pulled away from the frame due to the rust???. If rust has weakened the area, then simply welding back into place will not work. Also, the placement of the mount is critical to ensure that the ride height will be level. You probably should take it to a frame shop. They can probably reinforce the area and reweld. They may also suggest rebuilding that side of the frame with factory crash parts. This would involve more extensive cutting and welding, and would pass your auto insurance inspection (if you ever get into an accident that affects this area of your car).
I recall someone else having a similiar problem, I am not sure if it was on a W210, but try to search this board for more info.
Old Apr 28, 2004 | 01:17 PM
Whitey's Avatar
98 W210 Advantgarde
Ouch! Sounds like a major disaster...can't offer any help here but sorry to hear about this nonetheless Hope you're able to fix it...good luck!
Old Apr 28, 2004 | 01:21 PM
HONDA ACCORD
DELETE POST PRIVACY
DELETE POST PRIVACY
Old Apr 28, 2004 | 04:28 PM
E-Klasse's Avatar
W205 C300
Any one hear more about this recall?
Recall Re: Front Spring Towers
Service Action #01-0799: Check and repair both sem sealer on front spring support (Damage Code 062900398)
023411 Check and Repair both seam sealer on front spring support.
Old Apr 28, 2004 | 06:12 PM
rob_fed's Avatar
W204 C300 2010
The recall seems to cover preventative maintenance. From the benzworld posts, the "sem" sealer would prevent water from accumulating in the area in question.
I would contact your local dealer first, then Mercedes Benz directly. You indicated that some sort of glue is visible. Maybe the spring support was resealed previously and it still failed. Or maybe it is just the stock sealant you see. But if it did fail after the resealing, you may have an argument.
At any rate, if the above yields no resolution, you still need to get it fixed. Find a frame shop, for an estimate.
Old Apr 29, 2004 | 01:47 PM
HONDA ACCORD
DELETE POST PRIVACY
Old Apr 30, 2004 | 12:35 PM
rowingmurphy's Avatar
E420
Unhappy Broken Spring perch
Same thing just happened today to my W210 '97 E420 with 88K miles.
Let me know if you have any luck getting MB to repair.
Jerry Murphy
Old May 6, 2004 | 03:19 PM
HONDA ACCORD
DELETE POST PRIVACY
Last edited by mastakamasutra; Nov 18, 2014 at 04:14 PM. Reason: DELETE POST PRIVACY
