97 e320 stuck in limp mode
When hard transmission limp can be only cleared by SD level scanner, the conductor plates and shifter switch do not need programming.
If you plan to become DIY, now is good time to buy a scanner. The prices drop and now you can have a good one for less, than $200.
FIY there are 3 levels of trouble codes and the stored or historic code will not clear by scanner. Since that is inactive code - the computer will delete it after some cycling.
Good luck with your troubles.
I no longer own W210, but from what I check, the new, cheaper scanners don't cover 20 yo modules, so finding one that works for your car might take some effort.
I am still confused with your description. It indicate that you had soft limp, that would clear with ignition cycling.
Meaning if that was the case, you should not need scanner at all.
Get a picture what exactly scanner tells.
Monday I will update with all the codes stored in my Tcm and what the end result of getting this car back on the road required
My late friend was indy "European cars" mechanic, specializing in MB. He was flying for indy update training every year. Technology moves so fast in last generation, that this is what it takes to be professional.
West Coast dealers charge $150/hr or more and usually 1 hr is minimum.
