Will 2003 R230/SL55 wheels fir my 2001 W210/E320 ??
Old Jul 6, 2018 | 03:56 PM
JM Steel's Avatar
E320
Sizes from SL55
Fronts are part number 230 401 20 02
18x8.5 ET30
Rears are part number 230 401 21 02
18x9.5 ET33
Old Jul 6, 2018 | 08:32 PM
AndreNY's Avatar
couple of Benzos
yes they will
Old Jul 7, 2018 | 12:40 AM
raymond g-'s Avatar
99 E320
you may want to double check but I think the 2003 SL uses 14mm diameter lug bolt whereas
our 210 models uses 12mm with corresponding smaller ball seat. in addition, the bolt length
may differ, requiring longer/shorter bolt depending on the cross section of the rilm at the hole
Old Jul 7, 2018 | 12:25 PM
JM Steel's Avatar
E320
Thank you!!!
Old Jul 9, 2018 | 07:46 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Yup need rad bolt tho
Old Jul 10, 2018 | 08:59 AM
JM Steel's Avatar
E320
Thank you, so ther than the bolts I should be all good? The offsets are OK? I appreciate your help.
Old Jul 12, 2018 | 05:49 PM
yup yup. unless youre running super fat tires.
Old Jul 12, 2018 | 06:18 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Check Pelican Parts for the lug bolts. I got mine from them when fitting W211 wheels on my W210. The ones I ordered were no longer available and they sent ones that were equivalent, but more expensive, for no extra charge. They fit perfectly.
