Part 2
Old Aug 20, 2018 | 08:00 PM
Kevs e430's Avatar
2001 E430
Part 2
Sorry its a 2001 e430
Old Aug 21, 2018 | 12:23 AM
Kevs e430's Avatar
2001 E430
Run away benz
Hi sorry i did this in 2 parts .My e430 has high idle at start up but poor response from pedal.If i hit the gas pedal in idle it runs away.Also when this happens i get bas and esp lights also check engine light is on Just got it running 2 weeks ago had bad shifter thanks for that info any ideas?? Thanks kevin
Old Aug 21, 2018 | 01:16 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Is it hard to catch the gas pedal?
Old Aug 21, 2018 | 04:43 AM
Kevs e430's Avatar
2001 E430
Run away benz
When i touch the gas it runs away or it surges up and down with dead pedal thanks for your time!!
Old Aug 21, 2018 | 10:03 PM
Strigoi's Avatar
If you have a CEL get it scanned. There will be codes that will tell you what's going on. Have it scanned by someone that has Star/DAS/Xentry and not some cheap OBD scanner.
Old Aug 22, 2018 | 01:42 PM
Kevs e430's Avatar
2001 E430
Run away benz
Hi scaned with snap on solis ob2 and 32 pin link under hood p2032 2038 202e 2004 203c Thanks for your time i have 2001 e430 when i start up has high idle surges at times but mo responce from gas pedal Need help thanks
