2001 E430 4-Matic.... E55 engine swap?
Im currently looking for information on swapping an E55 AMG engine into my 2001 E430 4-Matic.
you will love it for sure, and deserve every cent..
you can put 98-02 "E55" Engine & gearbox, they're plug & play,,
you can also, tune your ECU, or put an "ECU/ESL/Key/EIS" from 01-02 "E55"..
-;ZAYED;-
but, "E430 4-matic" using (A400N), which is little bit weak to handle the "E55" power range,,
you can use it, but can't assure to you, if it can survive with hard pedal..
-;ZAYED;-
It's happening! This person claims to be using the existing 430 harness and stock ecu, and even says it won't recognize the beast under the hood. Seems pretty easy and straight forward. I wonder if this is the case with the e320?
The stock trans didn't last long. About a year. I guesse the early tranny's had weak thrust bushing or bearing and that's what failed on mine, I then swapped in a s500 trans and that's been holding up pretty good. The diff is starting to groan thoughts
