instrument cluster intermittently works
The alternative issue is that the internal flat connector ribbon(s) attached to the dial clusters inside the assembly are either loose or damaged. If this is the case, you would need to send out the cluster to a company that
specializes to instrument cluster repairs. I believe there are several recommended on the forum threads here - just do a search for 'instrument cluster'.
Here's an example of the flat ribbon(s) in the instrument cluster when disassembled. This is from a w202 c230K cluster.
I havent had to remove one of these on a w210 (only on the w202 model) but it should be similar.
If you DO decide to open up the instrument cluster itself, take your time, laid out with plenty of space, and document with photos each step you take when disassembling each part, piece so you know how-to reverse it when putting
it back together. Some small pieces may slip out (namely the smaller display/face plate pieces). You'll know what I mean when/if you attempt it (so you will know how it is re-placed when re-fitting/re-assembling the cluster.
If you do use those tools, be cautious with them.
You can test something - "most" W210's should run/operate without the cluster - so you might not be down/out when out/back for repair.
