Brembo brakes
Old Dec 16, 2018 | 10:36 PM
JONESER's Avatar
1999 E320
Brembo brakes
I found a set of front 4 piston Brembo calipers and stock rotors at the junk yard on a s430. I tried to put them on my ‘99 e320, the caliper look like it’s gonna work but the rotors not gonna. The diameter is 13” and that seems fine, the offset is too big and the back of the rotor is hitting the dust shield way before it sits on the hub. (Even with dust shield removed, the rotor would hit the lower ball joint before sitting on the hub) What is the correct rotor? What would it come off of so I can look at the junk yard? Thanks in advance!
Old Dec 17, 2018 | 09:09 AM
illest's Avatar
w210 AMG or S213
You will probably need 330 mm rotors from an SLK32
Pics of when I had that setup
Old Dec 17, 2018 | 12:17 PM
JONESER's Avatar
1999 E320
Are those the rotors you used? Are there any others that will work? I’d like to find a set at the junk yard if possible.
THANKS for your help!
I attached
a pic of the rotors I got and marked the problem in red. It’s the thickness, needs to be thinner.
Old Dec 17, 2018 | 02:54 PM
raymond g-'s Avatar
99 E320
Hollander Interchange Manual
File Type: pdf
Old Dec 17, 2018 | 03:53 PM
JONESER's Avatar
1999 E320
Thanks Raymond
Old Dec 18, 2018 | 09:58 AM
illest's Avatar
w210 AMG or S213
Front rotors form a e430 4matic should work
Old Dec 18, 2018 | 10:20 AM
JONESER's Avatar
1999 E320
