woodgrain steering wheels
BTW, do you remember what size the two torx screws are? Steve told me before to do mine but now I'd forgotten
Was it 27 or 25?
The allen bolt in the center is a 10mm I think - very difficult to remove as MB loctites it on I was told, so you might need to use a pipe to extend the allen wrench, as I did, to get extra leverage to remove it. Two wires run into the airbag, one for the horn, the other for the airbag - its just plug an play but when you do it, remember to remove your key from the ignition or you'll end up with serious problems.......
I've posted mine many times before so I'll spare you guys
Since I got a non-W210 wheel, the whole airbag had to be replaced, otherwise a wheel like E or a Brabus like Jimmy's (now elemnt1) would just use the OEM bag.
Hey E, where's the chrome rings?
Your new steering wheel and air bag look good so you should post it again.
Sorry to get off the subject. The chome rings do not look good with the white faces so I switched to this setup.
Your new steering wheel and air bag look good so you should post it again.....
but ///AMG cool too
who's ugly black wheel is that?????
thanks for the comps E:o I have Steve to thank for that...as I keep repeating....
vince
what kind of steering wheel was posted there with the wood on top and bottom with the plastic/metal star in the center? my last benz was a 300D and i really miss the jewel in the center of the wheel. that has been my only standing complaint with my 420 - the cheap looking steering wheel.
vince
I've been looking for the steering wheel like yours (different color). I prefer this style of wood steering wheel over the one w/ wood on top. Where did you get it ? And how much did you pay for it ? Do you have to replace the airbag ?
Is the steering wheel designed for the E class ? or is it for another model, and you manage to have it fit your car ?
Really nice interior you got there.
Mine? Yeah, love the old logo...matches my key ring
Also comes in grey/black or blue/black two-tone....IMO, completely updates the interior.
....with the W210 interior
vince
i do like your steering wheel too, but i was referring to the picture with the tan interior and the wheel on the left hand side - ya know (driver's side)
vince
hahhahaha! yeah, figured it out after I read your post again....looks like a Brabus wheel (same as Jimmy's above it) with a modded cap in the center but I may be wrong.....
Whitey
This airbag can be found on the CLK before 99 and on the older SL I think. The steering wheels from 95 to 99 on most S, C, E-Classes interchange so that you can use your original airbag.
hey E, what’s that on your dash? Did you make that or does someone manufacture them to cover the dash? Did you put that on because of cracks or to prevent them?
You can get it monogrammed too. Comes in 12 different colors.
Was it 27 or 25?
Recommend using a regular breaker bar (at least 50cm) to remove the wheel bolt, and having someone else hold the steering wheel steady (instead of using the steering wheel lock).
-s-
thanks,
Do you guys know who carries this wood steering for 210, 2000MY? I have those volume and command buttons on the steering wheel? and how much they cost??
thanks,
Pages 4 & 5
