E240 AC on/off issue
Old Mar 12, 2019 | 12:36 AM
Nader02's Avatar
E240
Hello all,
I am new to the group and I am not sure if this issue has been discussed in the past. I appreciate your help.
The AC off button on my E240 is on all of a sudden. When I try to switch it off, it blinks then stays on. As a result, the air is not cooling.
I will be trying the following:
1. Check the fuses.
2. Check if gas re fill is needed.
Before doing the above, can you please advise how to reset the AC/cooling system on the E240 (hopefully it will solve the problem).
Also, can you think of other things I should try apart from the above mentioned?
Thanks,
Old Mar 12, 2019 | 01:11 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
what year?
Old Mar 12, 2019 | 01:16 AM
Nader02's Avatar
E240
Originally Posted by MJ50
what year?
2002
Old Mar 12, 2019 | 01:23 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Mar 12, 2019 | 05:34 PM
Nader02's Avatar
E240
Well, I read somewhere in this forum that a reset (for another Merc model/C Class) is performed by pressing and holding the "Defrost" and "Recirc" buttons together.
Old Mar 13, 2019 | 11:45 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
http://www.mercedesmedic.com/ac-air-...le-codes-list/
Follow the sensor and codes readout from this page, including additional info in notes and if you can't draw the conclusion - post the numbers here and we help you.
