E320 no fuel at fuel rail cranks no start if i cycle fuel pump get no fuel to fuel ra
Old Jun 26, 2019 | 06:10 PM
Jeff Reno's Avatar
98 e320
E320 no start cranks fine i disconnected fuel line at fuel rail and cycled the pump got no fuel at all to rail
Old Jun 26, 2019 | 08:24 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Jeff Reno,
Welcome
Check the main fuse box ((under the hood) - fuse #6 I believe, for the fuel pump to see if it's blown.
Also check the fuse box under the rear seat - read here
Old Jun 26, 2019 | 09:32 PM
Jeff Reno's Avatar
98 e320
No start
Originally Posted by khomer2
Jeff Reno,
Welcome
Still wont start fuel pump fuse and relay good when i jump the fuel pump i get no fuel coming out of the line that connects to the fuel rail shouldnt there be fuel when pump is running to the rail?
Old Jun 27, 2019 | 11:15 AM
khomer2's Avatar
When was the last time you checked/replaced your fuel filter?
Old Jun 27, 2019 | 02:29 PM
Jeff Reno's Avatar
98 e320
No start fuel filter is new just been replaced
Fuel filter is new just replaced recently
Old Jun 27, 2019 | 02:49 PM
khomer2's Avatar
Any pressure at the rail?
Turn the ignition to position 2 and lmk what pressure it reads.
Edit:
When you checked the fuse box under the rear seat, did you check the fuel pump relay?
https://www.benzworld.org/forums/w21...ump-relay.html
Old Jun 27, 2019 | 06:40 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Famous K40 ?
The pump should come for few seconds just by turning the key to position 2.
Old Jun 27, 2019 | 06:57 PM
Jeff Reno's Avatar
98 e320
Pump comes on relay good swapped with another good relay same thing
Originally Posted by kajtek1
Famous K40 ?
There is no pressureat fuel rail even when disconnected and turn key pump comes on for approx 5 seconds but no fuel comes to the line going into the fuel rail at all
Old Jun 27, 2019 | 07:00 PM
khomer2's Avatar
Pull your Vmeter out and test the connectors where the relays are for power.
Also swap relays to make sure the relays themselves are functioning correctly.
Old Jun 27, 2019 | 07:06 PM
Jeff Reno's Avatar
98 e320
Relays good even disconnected wires at pump 12.7 volts even when cranking
Relay and fuse good disconnected wires to pump 12.7 volts even when cranking
Old Jun 27, 2019 | 07:09 PM
khomer2's Avatar
And you tested the relay to ensure it's functioning correctly, right?
https://www.wikihow.com/Test-a-Relay
EDIT:
Did you confirm what kajtek1 stated?
Old Jun 27, 2019 | 07:12 PM
Jeff Reno's Avatar
98 e320
Relay is good even swapped relay it works fine pump comes on for approx 5 seconds but still no fuel
Old Jun 27, 2019 | 07:18 PM
khomer2's Avatar
Sounds like the fuel pressure regulator.
https://www.benzworld.org/forums/w21...s-no-fuel.html
Old Jun 27, 2019 | 11:59 PM
kajtek1's Avatar
How do you know the pump comes on? Do you hear it? If the pump runs, but no fuel, you have pretty well narrowed problem.
