211 factory rims on 1996 E320??
-s-
Try a 12mm lug in the wheel. You can see what I mean by how little of the lug covers any "metal" and most if it is swallowed by the hole.
It works, I just wouldn't be putting any serious stress on those wheels.
Also, the wheels are subject to spinning on the hubs as the lugs don't fill the holes in the wheel properly. Thus the wheel will rotate back and forth. Eventually the stress of bending lugs back and forth will cause them to break. This is usually only an issue on cars that have higher engine power and heavier weight.
-s-
-s-
I will take pictures to illustrate...
-s-
The 16" wheels of the W211 would not enhance the look of your W210 that much (I actually prefer the W210 rims). If you want to improve both the look and handling, get the sport wheels of the W211. It looks great, and improve the ride of your car a bit.
-s-
-s-
Another alternative is I understand there are replicas of this wheel that has 12mm bolts.
thanks..
All W210 rims should fit all W210 cars, with the exception that minimum sizes are in effect for E55 and 4matic cars (generally 17", but it's a bit more complex than that).
-s-
