01 e320 4matic: how slow is normal?
Is it normal for car to not be able to get past 3200 or 3300 RPM when flooring it?
constructive to have the car scanned using a MB factory compliant scanner (SDS, STAR, clone).
I feel the RPMs may be low though
For first time ever, I pressed WOT and car came alive! Rev'ed to redline first time ever. It was able to do this one time more before it stopped completely being able to accelerate in this manner.
I will get car scanned with MB tools and update
1. Your "new" test: when on the highway in D - instead of kickdown - hold your shifter to the left for 3 secs - and your tranny should downshift to "power gear" for that speed - once at power gear THEN apply throttle to accelerate
2. Checking cats does not require MB tools - only need a IR thermometer and a rubber mallet.
(Front Cats) with your MB measure temp at the front pipe going into each cat - then measure the exit temp on each cat - if Exit temp is sincerely a cut higher than Entrance temp then front cat(s) are functional.
(Rear Cats) with MB off - use rubber mallet to tap/thunk each "rear cat" - which are hollow small drums with a screen inside - when tapping/thunk'ing you are checking for the sound of heavy loose "chunks" inside each rear can. If you detect those "chunks" then each rear can comes out - shake out the chunks - and resinstall - it's the heavy chunks in the rear cans which can be the Exhaust Choking here.
I want to take an ohm meter to the CPS and see what the resistance is when someone presses throttle (at least that is how I understand it)
Cant want to unleash all 230 HP one day.
Ill do the Cat test, thanks for tips. I did not know there was a second set of cats downstream
Not only Italian tune-ups work, but kicking WOT couple times a day will change the adaptations.
Do that for couple of days before jumping to mechanical conclusions.
And yes, gasoline engines don't have much torque when you drive at low rpm and try to accelerate 1/2 throttle. Each time I switch to gasoline car, I am close to creating accidents as I got used to diesel torque
Even when you press the pedal to the floor, gasser will "think what to do" for couple of seconds before downshifting, when diesel will pull like a train.
I have checked/replaced (had spares) MAF, throttle with TPS, brake pedal actuator assembly. I have reset the transmission "driving style" already.
Am I missing anything else? no codes. car should redline, right?
or
are you saying that there are no Check Engine Light codes via OBD scanner
(two vast differences in scanning)
car is still slow but I am getting used to it. Just wish it would redline but does not look to be in my cards.
Try to redline it on 3rd gear manually? If the engine will not get there in timely manner - something has to be wrong with it. But then a code should show.,
You should not have to get use to it, PLUS this could be affecting your gas mileage (although you haven't mentioned this yet)
I am sure the gas mileage is poor albeit I would have to calculate it to help assess how bad.
for STFTs LTFTs...is this a star only thing? does only MB dealer have STAR or do good indies also have access?
Not giving up haha
New plugs, new filters,
I am not sure if you need SD scanner to check engine.
Lifted W210 do have some data available via OBD plug, so if you have android, spending $5 for bluetooth plug and Torque app might be good start.
Not giving up haha
No CELs no codes.
It sounds like you have some sort of possible exhaust restriction.
You haven't commented on whether you tested the cats yet.... simple test: use temp gun method.
Do you have a 38pin connector under the hood? (I dont recall of the 01's req'd reading the other modules under the 38pin under the hood)
STFTs LTFTs - $tealer$ship if you have DEEP pockets or a good Indie that knows MBs (if they do not, run away....)
You need to read these FTs and the o2 sensor to see what is happening as well as if the o2 sensor is operating correctly.
I doubt your torque app and dongle will read FTs.
Either invest in a decent scanner or borrow one at get some readings.
No CELs no codes.
Dont see a 38 pin under the hood.
I would advise to spend $5 for Torque Pro upgrade.
Once you click "add a gauge" you will get to the list of sensors and modules, when those who apply will show in green. That will give you detailed list what you can do without going into $150 scanners.
So codes came back and there is a secondary air injection p0410 and there is "TID $03 CID $04 low sensor voltage for switch time calculation" ..
did some research....(secondary air pump ....I saw a thread about cleaning that system and looking for vacuum leaks, and then only thing I found about "low sensor voltage for switch time calculation" was something to do with bad ignition packs )
Now I am really in for a problem. forget the slow acceleration, at least she starts and drives. Now I have a CEL and smog due in 2 months!
however, it is a pending fault, hopefully pending means I can still pass smog.
I spent entire weekend opening and testing my instrument cluster with bulbs.
cleaning and inspecting the secondary air injection system seems very complicated, I have tried to read all the major threads. hopefully makes sense when I tear into it looking for leaks
