illuminated door sills
Old May 6, 2002 | 10:52 PM
paomien's Avatar
From: Long Island, NY / Mississauga, Ontario / Changhua, Taiwan
11 S550V4
Question illuminated door sills
Does anybody who has the illuminated door sills have them on the back sills? My dealer said they don't make them for the back , only for the front... ??
Old May 6, 2002 | 11:14 PM
Turbo]['s Avatar
98 E430
I have it on the front and rear. But mine are 3rd party, not OEM
Old May 6, 2002 | 11:22 PM
paomien's Avatar
11 S550V4
3rd party? where are they from? how much did they cost? are they a pain to install?
Old May 7, 2002 | 02:01 AM
Turbo]['s Avatar
98 E430
No, I got it off Ebay. It was quite cheap, compared to dealer's price.
It's also really easy to install. As for wiring all you need is a constant 12v, and wire the ground to the door switch.
Old May 7, 2002 | 10:03 AM
JamE55's Avatar
Out Of Control!
Check out e-bay! I've seen them being sold pretty cheap.
Old May 7, 2002 | 04:09 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
sills
I ordered aftermarket sills on Ebay for $200. That included 4 illuminated sills (2 front/ 2 back). Easy to install even if you have limited "know how" skills. The hardest part is just taking off the panels to hide/access wires. I can give you quite a few tips though for the W210 body. As for power, I tapped into the rear dome light for all 4 sills. It was the easiest route compared to tapping into the battery or front dome light.
Old May 7, 2002 | 09:21 PM
paomien's Avatar
11 S550V4
ok thanks! it almost seems like the two words "mercedes benz" won't fit into the rear doorsill, but i'll give ebay a try, and keep everybody posted! thanks again!
Old May 7, 2002 | 10:19 PM
Turbo]['s Avatar
98 E430
Here is a pix of the rear door sill I have on my car.
http://members.directvinternet.com/r...door_sills.jpg
Old May 8, 2002 | 01:57 AM
ryson's Avatar
it will fit
paomien,
It will fit. It's just the front door sills have a longer metal frame around the words Mercedes Benz. The rear sills are shorter but the lettering is the same size as the front.
Old May 9, 2002 | 02:36 AM
paomien's Avatar
11 S550V4
Talking
Thanks all! I will bid on a set from ebay. How long did it take you guys to install??:p
Old May 9, 2002 | 10:45 AM
ryson's Avatar
time to install
Considering I had to figure out how to pull off the panels, it took me longer. It took about 5 hours to do all 4 sills.
