Replacement Key
Old Aug 12, 2021 | 09:53 AM
devildog832916's Avatar
2009 S 550
Unhappy Replacement Key
Hello Group,
I have a 1999 E430 and I need a replacement ignition key? I've searched high and low on the internet and trying to avoid the high cost from a dealer, any suggestions?
Old Aug 13, 2021 | 11:11 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Originally Posted by devildog832916
Hello Group,
Dealer only. Bring proof of ownership. Either the dealer can "teach-in" the key or you should be able to do so. Documentation indicates it takes about 75 minutes. FWIW, the key will come out of Dallas, Texas. If you have lost a key, the dealer can disable that key in the car's electronics so the lost key can no longer be recognized by the car.
Old Aug 13, 2021 | 01:09 PM
raymond g-'s Avatar
99 E320
Yeah, gone are the days were we can get them for about $60 online (as I recall). Sadly, we became victims of our success getting 'group buys' together. Within months, MBUSA shut those efforts down by implementing THEFT RELEVANT PARTS policy for US dealers. So yes, you must bring in the car and prove ownership. In rare cases, an authorized locksmith can visit your remote site and perform the task.
Try calling around to see what the dealer charges for the key. They may also try to add on "programming" in addition to the key but in nearly all instances, it's simply inserting the Smartkey into the ignition and letting the two units interrogate, handshake and synchronize their brains....like Spock and the mind meld trick. So you MAY want to read up on this and see if you can save yourself $50+ and stick it to the dealer by sticking it in yourself.
On average the dealer may charge $250-400 for the Smartkey and about $100 for the matching metal blade key. Call around to any MB dealer nearby which you're willing to drive to as the price is set by independent dealers themselves. SHOP AROUND.
A few years back, I checked the cost to the dealer and it was more like $75 and $10....(sigh)
Old Aug 14, 2021 | 03:11 AM
davmil2002's Avatar
320e
Aftermarket key replacement
I bought one from a locksmith I found on Facebook Marketplace for $180; incl. FOB with bladed key and programming about 5 months ago for my 1999 E320 Sedan. Bought it b/cuz I lost the 2nd key and wanted a spare just in case.
I sat there while he did it (30 min) and he let me test every function repeatedly to make sure it worked. The old one still works. I've had and used it exclusively for 5 months without issue. This was in Atlanta area -- hopefully you can find one in your area. Worth shopping around in there if the MB dealer is trying to get too much.
dave
Old Aug 14, 2021 | 02:36 PM
raymond g-'s Avatar
99 E320
sweet, davmil2002. I seem to read trickles of independents figuring a way around the dealer and tech restrictions. Reports of
overseas creative minds having bypassed and learned how to program Smartkeys have been shared for a few years now.
If you find contact for the Facebook Marketplace, please post - I'd sure love to reach out to them
Old Aug 15, 2021 | 04:21 AM
davmil2002's Avatar
320e
The guy I went to was an immigrant from (i forgot) Eastern European country working as a locksmith outside Atlanta. He knew and had a password to get into the Mercedes Central security computer (that's his description). He took my VIN and fed it into the Mercedes interface and then downloaded the code/file, whatever it was, and then programmed my new FOB. He definitely knew what he was doing but wasn't at all pretentious about it. He was a lucky find - from the time I came across his ad to completion was only about a day.
Old Aug 17, 2021 | 04:03 AM
davmil2002's Avatar
320e
Found his business card:
Stefan Olariu, GM
678-650-3337
allcarslocksmith.com
Recall is was ~$180 for FOB and programming (My rig is a 1999 E320). He's located just outside Atlanta. Super guy and I'm sure he'll guarantee his work.
Old Sep 12, 2024 | 02:13 PM
Trampas Stern's Avatar
W210
Stefan Olariu, GM
678-650-3337
I buy used keyfob from Ebay then unsolder the big IC (encryption chip) and swap to keyfob from ebay. I have done this 3 times as the fobs wear out.
Old Sep 12, 2024 | 02:52 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
True statement. There is information on this technique on this forum if one searches.
Old Jun 1, 2025 | 01:45 PM
MacVidMB-V8's Avatar
W209, W124
This only works if you have an original key. With no keys at all, you need locksmith or dealer.
