Help me pls with E55 W210 bumper, driver side fender, headlights
Recently got an accident, damaged the bumper, driver side fender, headlights. As I am new to MB parts, please help to identify part numbers, as well as answer my questions such as whether regular headlights are gonna fit E55 body or not, is it better to get a bumper and fender from junkyards or I can get new? Have anyone put OEM Apollo R19 on any W210, any objections or not.
It's silver color #744. I'll keep this thread up to date as I progress with the repair. Thank you guys in advance.
UPDATE 03.25.2022:
I had to replace the radiator as well part number for which is 2105004703.
Headlights: 210-820-43-61. Many online private sellers, yet not sure if its going to fit.
Hood: 2108800957 / A2108800957 / A 210 880 09 57 0957
Fender: w/o AMG package - MB1240126C Bumper w/o washer : MB1000143
Hope it helps.
Grille: 302244178
The damaged car has HID headlights and the headlights for 2000-2002 E320 should fit.
I doubt anyone can help you ID the part numbers (including matching exact color vs part numbers) via the keyboard. This is quite a process. You can try identifying part numbers online but that is still only 80% certainty as some parts are VIN specific and all
....this DVD set is a clone of MB database and works well if your computer meets the specs for installation. otherwise, the official MB version is like $100+/yr online subscription https://www.ebay.com/itm/224588147516
To me it looks like you are going to need more than the parts listed - hood for example, plus the various bits behind the bumper and headlight. IMO it will be worth subscribing to the Mercedes parts catalog in order to research all the parts. Mercedes ISPPI system is the parts catalog. Part numbers by VIN, data cards, etc. can be accessed there. Current annual subscription is $92 effective January 2022.
Since only 500 or so of each year were imported I think there will be slim pickens for bumper and fender. May try LKQ.
The AMG specific fenders were replaced by the "normal" fenders a long time ago. The only difference between to two is that the AMG fender had the inner edge of the wheel well opening rolled to clear the wider 18" tires. That is to be done by the body shop replacing the fender. That was/is noted in the parts system. The same thing happened with the W202 C36/C43 fenders. The bumper is AMG specific. I would check with a good dealer, but it may have been discontinued. Used will be tough too - bumpers are one of the parts that most often are destroyed in a collision. And just in case the OP is not aware - unless you can find a good used part with the correct color in good condition - you are in need of a good body shop to do paint work. New parts only come in primer.
