at my whits end with this, wtf --someone smart and knowledgeable PLS need help
replaced them and the car ran like a dream
all the front cat biscuit had broken up and lodged in rear cat to cause blockage- suffocated the motor ---wouldn't run
so had towed - and the best exhaust shop in 100 miles got new aftermarket cats and put on ---$2000 later, sweet, fkn thing runs like a CHAMP, like a champ i say
UNTIL .... until i get home, 30 min away ....
....as i pull into driveway CEL goes on and stalled
ok so didn't get too concerned bc mechanic did say that i might want to clean or replace the MAF sensor ... he said it appears to be running ever so slightly lil rich, and maybe could be from the MAF---ok i go and check the codes.
damnit -few codes now
the first gang of codes were/are same codes as prior to replacing the cats. i was getting miss-fire codes on all cylinders.
my first effort was/did that i replaced the coils/wires/plugs= bc of the misfire codes. then that code came back and wouldn't run...ok so i deducted down to the cats AND the professional mechanic/guy even agreed with me --- so he/we changed the cats
BUT so the 2nd / last code was MAF p-0100
so instead of buying a 500$ MAF Sensor i tried cleaning it for 10$----everything ran great until it runs for a while=== almost as if like once under the hood get warm or something it dies.
so after work today i drove home and all was great and fine 20 min drive stopping/starting went to staples, etc etc
- but again as soon as i get home the car dies pulling up to mailbox to check mail.
so but it when dying today it didn't throw any codes- if CEL light not on, will my obbd reader maybe till see/get code??
I will check in few minutes
BUT so are we thinking that it is MAF?
he ran compression tests and all sorts of diag stuff and seemed to think this was ready to rook-n-roll
PLEASE looking for maybe someone that is savvy and stuff about possibilities ?? pls thx in advance
fuel pressure test gauge
I will also add --- AND This is WEIRD
even since i got it back, and i manage to crawl it into driveway ---the alarm will sound for like 45min ish, every 10 min the alarm sounds,
after an hour it stop - iow...i leave keys in it the alarm will not sound.
but locked up and walk into house with keys...it sounds every 10 min ish.
alarm didnt sound today though
but car died by burger king today and that sucked. but sat for 30 min and then it ran fine
I think i am going to try to insulate the MAF sensor and protect it from excessive heat coming up from the cat/block/manifold --see if that helps/changes things
i thought that the heat is maybe messing with one of the sensors? till it dissipates then not do it. it did it whether or not i had locked the car or not. meaning even unarmed the alarm would sound.
I removed #19 fuse under seat which my research yielded was the defroster and alarm fuse,... it still sounded off wtf
to town
Got there off hwy, died
Got it into parking lot
No cel, but Got on obb2 reader
P0100, and p0110.
Air flow and air temp sensor.
Maybe guess I need them replaced....
No cel. But that's what reader is giving
p0100 and p0110
so i wonder though... if it works when cooled down, and fails when hot---is that an indication that is it bad cps??? or would even a perfectly fine cps have same trouble
bc and i only ask ...bc since the new cats are in, it really feels as though the engine compartment (upon lifting hood) is soooo much hotter than before... just kinda feels real hot and smells hot.
but i am not getting overheating signs in car, but sticking head over the engine and over the cats thru that space there- is really warm. i have infrared thermometers and i can measure the temps of surfaces in/around the area/s of cps or maf.
I got a fuel line pressure tester - and will hook that up when i get home tonight.
but to get folks caught up to speed, i have a NEW Bosch MAF sensor on its way
maybe i also do the cps. but my question kinda still stands though- would a perfectly running cps fail or not work great if it got too hot.---or bc it is bad that this fail due to temp occurs?
I have even thought of taking some rockwool, and aluminum foil and insulating the MAF sensor --or try to anyways from the heat and see if that makes any difference
i dont have the data base of what psi i should have but on YT i am seeing/hearing that my psi should be between 45-55 ish psi
well i had 45psi at first click of key and once started i was at 50-55 ish
go out and can be very frustrating since the symptoms are sporadic but generally come to life (die, actually) when
engine is hot. once it cools, it acts normally...over and over. it may be a simple thing to try (like 1999E320 suggested)
scroll down and check under CRANKSHAFT POSITION SENSOR and see what you think
ok yeah i agree - i will get a new one
but the videos i saw i guess there are a couple different types. so i will look see which one it is i have and get the right one
but i agree ...from yt vids and stuff i think it could also be cps failure when hot
- and one of the videos i watched the guy said his failed right around 89k miles, mine has 92, so it sounds fitting to replace that and
the maf sensor will be here tomorrow and i think local shop has teh cps they can have here in just a day or so.
thx!
threw that in,
not getting all the misfire codes as before,
but still getting MAF circuit --but i haven't cleared them yet either.
but it says pending--what's that mean, its just not confirmed yet or somthing...tbh idr if it was there last time or not, but maybe explains why there is no CEL on
ALSO it reads MAF circuit---is that trying to tell me maybe its the harness/connector or smth? that is issue vx maf filter sensor? or idk maybe they just using the term loosely and the circuit that normally fails is the sensor end of it, the business end of things?
didn't read again jonnie on the spot, fired it up and drove 1m down street
and came back as it started to stall on me at light
came right back
So the bosch CPS is next
ftr the MAF Sensor was bosch
can the fuel line tester like just stay on for 20 min and see if pump maybe fails over a duration of time?
is that i need to change the cps, but throws a pending code of MAF circuit
so like is it always kinda like this or just this case with the cps and not throwing codes for the cps? Not even a pending one
imma go out and read again now that i am back & it's cooled and stuff
right on right on
i got it out ---took 30 min for the one damn screw, but yt very helpful
part in thursday
so excited, i bought the car in janurary and been dying to drive it and not worry about breaking down
but i bet before the cats clogged up on me, that the cooler weather is what maybe made the cps a non-issue
until hotter weather when i got it back
dropped it off in early march and got it back like week or so ago- 88f out and that prolly the cps issue then reared its head with hotter temps
