Need Help on Right Mirror Fix
Yesterday I realized that it was because the right mirror was not working properly.
I never had such a car before, however, apparently, the car adjusts the position of the side mirrors, when I switch gear to D and to R. The left mirror was changing its position smoothly. However, the right mirror struggles. I could hear duh duh duh noise from it. And when the right mirror stops its struggle, the mirror is facing too much up, showing street lights when driving.
This has been dangerous for me when I'm driving, because I can only properly adjust the right mirror when there is a passenger on the passenger side, who can help me manually press the right now down so that I could see the traffic on the right side.
I cannot adjust right mirror myself. If I park the car and adjust the mirror myself, the right mirror will go back to the upward position when I switch to D or R.
I hope I can try to fix the right mirror without replacing it. I have found some videos regarding how to replace a side mirror. I also found thread here on how to fix a floppy side mirror (https://mbworld.org/forums/e-class-w...-w210-fix.html). I don't know how to describe the problem with my side mirror. However, I don't think it is floppy. To conclude, I haven't found a video or tutorial that fixes a improperly operating side mirror. Do you have some advice on how I may approach the problem? Shall I probably try to open the side mirror and take some photos, so that you may provide suggestion on what the problem may be?
Alternatively, I hope to just disable the automatic side mirror adjustment. My other car is a 7-seter Opel Zafira A, which I almost never adjust the side mirrors. However, I haven't found a button to disable automatic side mirror adjustment on the E240. Is there such a button?
Thank you in adavance!
